coq-club - [Coq-Club] Re: [Agda] Re: Agda beats Coq
chronological Thread
  • To: Nils Anders Danielsson <nad AT Cs.Nott.AC.UK>
  • Cc: Edsko de Vries <Edsko.de.Vries AT cs.tcd.ie>, Agda mailing list <agda AT lists.chalmers.se>, coq-club <coq-club AT pauillac.inria.fr>
  • Subject: [Coq-Club] Re: [Agda] Re: Agda beats Coq
  • Date: Thu, 20 Nov 2008 15:06:13 +0100
Hi,
Le 20 nov. 08 à 14:29, Nils Anders Danielsson a écrit :
On 2008-11-20 12:05, Edsko de Vries wrote:
fix-fac-ind : {g : Nat -> D Nat} {n k : Nat}
          -> fix-aux g fac-aux n ↓ k
          -> fix-aux (fac-aux g) fac-aux (suc n) ↓ suc n * k
fix-fac-ind {g} {n} pf with fac-aux g n ⋆
fix-fac-ind {g} {n} {k} converge-now | inl .k = converge-now
fix-fac-ind (converge-later pf) | inr y = converge-later (fix-fac- ind pf)
I don't know Agda very well, but there is some magic going on in fix-fac-ind!
The magic is called "magic with" (but is not really magic). See
http://appserv.cs.chalmers.se/users/ulfn/wiki/agda.php? n=Docs.MagicWith
for a quick explanation. Definitions using magic with can be translated
into equivalent definitions which do not use with, see Ulf Norell's
thesis for a detailed story.
The crux of the problem in Coq is that you need dependent induction on the premise
(otherwise the proof is closed, not K/JMeq needed here).
Lemma fixFacInd : forall (g:nat -> Delay nat) (n k:nat),
 converges_to (lfpAux g facAux n) k ->
 converges_to (lfpAux (facAux g) facAux (S n)) (S n * k).
Proof.
  intros g n k H.
  dependent induction H ; revert H.
  setoid_rewrite unfold_lfpAux_id at 1 2. simpl.
  destruct (facAux g n) ; simpl ; simplify_dep_elim.
  constructor.
  revert H0.
  constructor.
  apply IHconverges_to. reflexivity.
Qed.
Also, we don't need the ⋆ definition in Coq (Edsko didn't even bother to define
it), is it required in Agda or just useful combined with "with"?
Cheers,
-- Matthieu
