- To: "Aaron Bohannon" <bohannon AT cis.upenn.edu>
- Cc: "Agda mailing list" <agda AT lists.chalmers.se>, "coq-club" <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Re: Agda beats Coq (was: Termination proof in partiality monad)
- Date: Sat, 22 Nov 2008 22:25:51 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=from:to:subject:date:user-agent:cc:references:in-reply-to :mime-version:content-type:content-transfer-encoding :content-disposition:message-id; b=OaYjglHLIadd7x4HE3w0ImkYa+CMfCFsuLUW59DIqjDozUDByCLAlvHzLHP8irLUpw GqlOqZ2s3kOmzM0LCkSc2Mz59D/TMuoCrcWiBYG65ORyJPHoAQhgxQDqnfnVa1TcjF58 OfFwJwVPNIa2mnPJPjac+ESF0qx9bTZ3l4Kas=
On Saturday 22 November 2008 1:23:52 pm Aaron Bohannon wrote:
> I have been trying to working coinductive data and definitions
> recently and have found that Coq been very helpful in developing
> intuition about this sort of thing. So I found your remarks below
> very interesting. Specifically, you seem to imply that a
> CoInductive/codata definition in Coq/Agda permits some operations that
> an abstract type with an "observe" function would not permit. Can you
> (or anyone else) be more specific about what these would be?
(It should be noted that I have experience only with Agda's codata, so I'm
simply assuming that Coq's CoInductive is about the same.)
I wouldn't say that one permits operations that the other doesn't. I'd rather
say that the intuitions promoted by one are better or worse for helping write
correct proofs/reasoning about your programs. Specifically, it leads one (me
at
least) to think that various expressions involving codata should behave like
their syntactically-almost-identical analogues with data/Inductive, *but they
don't*. Perhaps the biggest problem is using the codata coconstructors (for
lack of a better term) as if they were data constructors.
Consider the type of natural numbers:
data Nat : Set where
zero : Nat
suc : Nat -> Nat
And suppose we have:
i, j, k : Nat
j = suc i
k = suc i
And we want to know if j == k. Well, this is easy, because we see that j and
k
were both built using i and the suc constructor. That's how inductive data
works, two values are the same if they were *built* the same way.
So now we turn to the codata analogue:
codata Conat : Set where
cozero : Conat
cosuc : Conat -> Conat
And we consider:
i, j : Conat
i ~ cosuc i -- ~ is used in Agda instead of = for corecursive definitions
j ~ cosuc i
And we want to know if i and j are the same. Now, the syntax here might lead
one (me certainly) to think that this is just trivial. i and j are *built*
the
same way, so they must be the same, just like inductive data. However, that's
*not* how codata works. Two coinductive values are the same if *they produce
the same series of observations*. So, proving i and j are the same is no
longer trivial, and you have to talk about how one is a bisimulation of the
other and such.
If we look at the categorical semantics of the two types, we may figure out
where things are going wrong. Inductive types can be given initial algebra
semantics, where Nat above goes something like:
N X = 1 + X is a functor
(A, a : N A -> A) is an algebra for that functor
Nat is an initial object in the category of such algebras, which means that
for any other algebra that fits the above form, there is a unique morphism
from the Nat algebra to it. This looks like (using Agda for notation):
cataNat : {A : Set} -> A -> (A -> A) -> Nat -> A
And "cataNat" should be a pretty familiar function:
cataNat z s zero = z
cataNat z s (suc n) = s (cataNat z s n)
So, just to be explicit, using inductive constructors to build inductive
values corresponds to applying the morphism of the algebra, and pattern
matching corresponds to using the unique morphism whose existence was proven
by initiality. Now, consider coinductive types, which are given by terminal
coalgebra semantics:
C X = 1 + X is a functor
(A, a : A -> C A) is a coalgebra for that functor
Conat is a terminal object in the category of such algebras, which means
that for any other coalgebra that fits the above form, there is a unique
morphism from it to Conat. This looks like:
anaConat : {A : Set} -> (A -> 1 + A) -> A -> Conat
Which looks like:
anaConat f a with f a
... | inl () ~ cozero
... | inr a' ~ cosuc (anaConat f a')
However, there's a subtle difference in the way this corresponds to the
categorical semantics that differs from the inductive case. While in the
inductive case, application of the algebra morphism corresponded to building
a
value with a constructor, in the coinductive case, *it corresponds to
destructing a coinductive value and looking at it*. In other words, pattern
matching. In short, one might say that for inductive data, building is
simple,
and destroying is complex, whereas the opposite is true for coinductive
codata.
And, I think that the coinductive syntax is misleading on this front, when
you
see:
j ~ cosuc i
You may think, "j is built from an i and a cosuc constructor", but *this is
not the case*. Rather the "cosuc" used as a constructor is better thought of
as something like:
cosuc n = anaConat f (Just n)
f : Maybe Conat -> 1 + Maybe Conat
f (Just n) with observe n
... | inl () = inr Nothing
... | inr n' = inr (Just n')
f Nothing = inl ()
Which has the net effect of producing one additional 'inr' observation beyond
whatever the original Conat produced. Of course, this is probably overly
elaborate, but the point is that the value in question cannot simply be
thought of as trivially as the previous value with another constructor box
wrapped around it.
(I realize this is probably confusing, since I just defined anaConat in terms
of cozero and cosuc. It might help to look at Anton Setzer's proposed
coalgebraic syntax for corecursive functions, where instead of working with
pseudo-constructors like cosuc, you simply describe the observations you see.
Then you can define the pseudo-constructors and corecursion in terms of this
primitive:
cozero * = inl ()
(cosuc n) * = inr n
(anaConat f a) * = bimap id (anaConat f) (f a)
where:
bimap : {a b c d : Set} -> (a -> c) -> (b -> d) -> a + b -> c + d
bimap f _ (inl a) = inl (f a)
bimap _ g (inr b) = inr (g b)
Hopefully that's clear.)
And, of course, this explains why indexing with specialized codata
'constructors' in a family doesn't seem to work very well, because:
data Foo : Conat -> Set where
bar : {c : Conat} -> Foo c -> Foo (cosuc c)
Is not simply working with constructors. It'd be akin to writing something
like:
data Baz : Nat -> Set where
blorf : {n : Nat} -> Foo n -> Foo (quux n)
Where quux is some arbitrary function. Except the situation is probably even
worse, because normalization of quux n probably helps (I'm not exactly sure
what the dual situation situation with inductive data is. Perhaps Foo (quux
n)
-> Foo n, where you'd have to compute the inverse of quux, or otherwise prove
something onerous merely to construct a value), whereas you can't simply turn
a coinductive value into some normal form consisting of only constructors
(since it's potentially infinite).
So, to sum up, it seems to me that codata/CoInductive encourages one to think
about coinductive values in the same way as inductive values despite that
that
leads to mistakes. The coalgebraic formulation and explicit observation (or
not; Anton Setzer explained how to think of the current syntax in terms of
his, and Nils Anders Danielsson showed here earlier how you can use pattern
matching on coinductive values in lieu of a destruction operation, since
pattern matching is the codata operation that corresponds to the coalgebra
morphism) is closer to the actual semantics, and seems to stop these think-os
from happening (rather than fixing up an inductive-like use with some
explicitly placed evaluation, like you see in some of the original proofs for
the partiality monad).
Anyhow, I think that's about the end of my rambling. Hopefully that was
useful
to you or someone else, but even if not, it helped me to get my thoughts on
the situation in order. As a caveat, I should note that the categorical
semantics above are only good for inductive and coinductive types, not
inductive and coinductive families and such that you'll find in Coq and Agda.
The relevant literature for the latter is a bit above my head at the moment.
Nevertheless, I think it's good enough to elucidate the source of the
problems
people are having currently.
Also, if anything I said above was incorrect, I hope someone will correct me.
Cheers,
-- Dan
- Re: [Coq-Club] Re: [Agda] Termination proof in partiality monad, (continued)
- Re: [Coq-Club] Re: [Agda] Termination proof in partiality monad, Vladimir Komendantsky
- Re: [Coq-Club] Re: [Agda] Termination proof in partiality monad, Edsko de Vries
- Message not available
- [Coq-Club] Agda beats Coq (was: Termination proof in partiality monad), Edsko de Vries
- [Coq-Club] Re: Agda beats Coq, Nils Anders Danielsson
- [Coq-Club] Re: [Agda] Re: Agda beats Coq, Matthieu Sozeau
- [Coq-Club] Re: Agda beats Coq (was: Termination proof in partiality monad), Dan Doel
- Re: [Coq-Club] Re: Agda beats Coq (was: Termination proof in partiality monad), Aaron Bohannon
- Re: [Coq-Club] Re: Agda beats Coq (was: Termination proof in partiality monad), Dan Doel
- Re: [Coq-Club] Re: Agda beats Coq, Xavier Leroy
- Re: [Coq-Club] Re: Agda beats Coq, Arnaud Spiwack
- Re: [Coq-Club] Re: Agda beats Coq, Aaron Bohannon
- Re: [Coq-Club] Re: Agda beats Coq, Dan Doel
- Re: [Coq-Club] Re: Agda beats Coq (was: Termination proof in partiality monad), Thorsten Altenkirch
