- To: Dan Doel <dan.doel AT gmail.com>
- Cc: Agda mailing list <agda AT lists.chalmers.se>, coq-club <coq-club AT pauillac.inria.fr>
- Subject: [Coq-Club] Agda beats Coq (was: Termination proof in partiality monad)
- Date: Thu, 20 Nov 2008 12:05:24 +0000
Hi,
A proof that is easy in Agda is hard in Coq.. scroll down for details :) I'd be very interested to learn how to translate the Agda proof to Coq, or even in a reference that describes the magic that makes the Agda proof so simple.
On 20 Nov 2008, at 00:15, Dan Doel wrote:
All right. In light of the input (I didn't realize I was bumping into the same
old usual problem with codata), I've reformulated the proofs into something
more akin to Anton Setzer's coalgebraic approach, and got something that types
now. Enjoy (Prelim again contains Nat and Sigma):
module Partial where
data _⊎_ (a b : Set) : Set where
inl : a -> a ⊎ b
inr : b -> a ⊎ b
codata D (a : Set) : Set where
now : a -> D a
later : D a -> D a
_⋆ : {a : Set} -> D a -> a ⊎ D a
now a ⋆ = inl a
later da ⋆ = inr da
never : {a : Set} -> D a
never ~ later never
return : {a : Set} -> a -> D a
return x = now x
infixl 40 _>>=_
_>>=_ : {a b : Set} -> D a -> (a -> D b) -> D b
da >>= f with da ⋆
... | inl a ~ f a
... | inr da' ~ later (da' >>= f)
map-D : {a b : Set} -> (a -> b) -> D a -> D b
map-D f da with da ⋆
... | inl a ~ now (f a)
... | inr da' ~ later (map-D f da')
fix-aux : {a b : Set} (k : a -> D b) (f : (a -> D b) -> a -> D b) -> a -> D b
fix-aux k f a with f k a ⋆
... | inl v ~ now v
... | inr _ ~ later (fix-aux (f k) f a)
fix : {a b : Set} (f : (a -> D b) -> a -> D b) -> a -> D b
fix = fix-aux (\_ -> never)
module Convergence where
open import Prelim
open import Partial
mutual
infix 35 _↓_
_↓_ : {a : Set} -> D a -> a -> Set
dx ↓ v with dx ⋆
... | inl x = ConvergeNow x v
... | inr dx' = ConvergeLater dx' v
data ConvergeNow {a : Set} (x : a) : a -> Set where
converge-now : ConvergeNow x x
data ConvergeLater {a : Set} (dx : D a) (v : a) : Set where
converge-later : dx ↓ v -> ConvergeLater dx v
_↓ : {a : Set} -> D a -> Set
_↓ {a} dx = Σ a (_↓_ dx)
map-D-↓ : {a b : Set}{dx : D a}{v : a} (f : a -> b) -> dx ↓ v -> map-D f dx ↓
f v
map-D-↓ {a}{b}{dx} f pf with dx ⋆
map-D-↓ {a} {b} {dx} {v} f converge-now | inl .v = converge- now
map-D-↓ f (converge-later pf) | inr y = converge- later (map-
D-↓ f pf)
-- Sorry this isn't so pretty. This isn't ever used anywhere, but it may be
-- instructive I suppose.
(f : a -> D b) -> dx ↓ v -> f v ↓ v' -> dx >>= f ↓ v'=-↓ : {a b : Set} {dx : D a}{v : a}{v' : b}
| inl .v | inl .v' = converge-now=-↓ {a}{b}{dx} f pfa pfb with dx ⋆
=-↓ {a}{b}{dx}{v} f converge-now pfb | inl .v with f v ⋆
=-↓ {dx} {b} {_} {v} {v'} f converge-now converge-now
=-↓ f converge-now (converge-later pf) | inl .v | inr y = converge-later pf
=-↓ f (converge-later y) pfb | inr dx' = converge-later (>>=-↓ f y pfb)
module Factorial where
open import Prelim
open import Partial
open import Convergence
fac-aux : (Nat -> D Nat) -> Nat -> D Nat
fac-aux _ zero = return 1
fac-aux fac (suc n) = map-D (_*_ (suc n)) (fac n)
fac : Nat -> D Nat
fac = fix fac-aux
fix-fac-ind : {g : Nat -> D Nat} {n k : Nat}
-> fix-aux g fac-aux n ↓ k
-> fix-aux (fac-aux g) fac-aux (suc n) ↓ suc n * k
fix-fac-ind {g} {n} pf with fac-aux g n ⋆
fix-fac-ind {g} {n} {k} converge-now | inl .k = converge-now
fix-fac-ind (converge-later pf) | inr y = converge-later (fix-fac- ind pf)
fac-↓ : forall {n} -> fac n ↓
fac-↓ {0} = 1 , converge-now
fac-↓ {suc n} with fac-↓ {n}
fac-↓ {suc n} | n! , pf-n!-↓
= (suc n * n! , converge-later (fix-fac-ind pf-n!-↓))
I don't know Agda very well, but there is some magic going on in fix- fac-ind! I tried to port your development to Coq, and most of it is easy, but I get stuck in that proof. I think Agda is doing something behind the scenes that is not obvious to me how to replicate in Coq. For the curious, I have attached my Coq development. I'd be very interested to see how this proof can be translated.
And there you have it. A genuine proof of convergence for factorial that
passes the type checker. Proof for a version of fix that actually works
correctly is left as an exercise to the reader. :)
Also, you cheated a little and removed the use of bind in the definition of faq ;-)
Edsko
(** (Incomplete) Coq translation of Dan Doel's proof of convergence of faq *)
Require Import Arith.
Set Implicit Arguments.
CoInductive Delay (A:Set) : Set :=
| Now : forall (a:A), Delay A
| Later : forall (d:Delay A), Delay A.
Fixpoint unfold_delay (A:Set) (n:nat) (d:Delay A) {struct n} : Delay A :=
match n with
| 0 => d
| S n' => match d with
| Now a => Now a
| Later d' => Later (unfold_delay n' d')
end
end.
Lemma unfold_delay_id : forall (A:Set) (n:nat) (d:Delay A),
d = unfold_delay n d.
Proof.
induction n ; auto ; simpl ; intros.
case d ; intros ; auto.
rewrite <- IHn ; reflexivity.
Qed.
CoFixpoint never (A:Set) : Delay A := Later (never A).
Implicit Arguments never [A].
Definition returnD (A:Set) (a:A) : Delay A := Now a.
CoFixpoint bindD (A B:Set) (x:Delay A) (f:A -> Delay B) : Delay B :=
match x with
| Now a => f a
| Later d => Later (bindD d f)
end.
CoFixpoint mapD (A B:Set) (f:A -> B) (d:Delay A) : Delay B :=
match d with
| Now a => Now (f a)
| Later d' => Later (mapD f d')
end.
CoFixpoint lfpAux (A B:Set) (k:A -> Delay B)
(f:(A -> Delay B) -> (A -> Delay B))
(a:A) : Delay B :=
match f k a with
| Now a => Now a
| Later _ => Later (lfpAux (f k) f a)
end.
Definition lfp (A B:Set) : ((A -> Delay B) -> (A -> Delay B)) -> A -> Delay B :=
lfpAux (fun _ => never).
Inductive converges_to (A:Set) : Delay A -> A -> Prop :=
| converges_now : forall (a:A),
converges_to (Now a) a
| converges_later : forall (d:Delay A) (a:A),
converges_to d a -> converges_to (Later d) a.
Hint Resolve converges_now converges_later.
Definition converges (A:Set) (d:Delay A) : Prop :=
exists a:A, converges_to d a.
Lemma map_converges_to : forall (A B:Set) (d:Delay A) (a:A) (f:A->B),
converges_to d a -> converges_to (mapD f d) (f a).
Proof.
induction 1.
rewrite (unfold_delay_id 1 (mapD f (Now a))) ; simpl ; auto.
rewrite (unfold_delay_id 1 (mapD f (Later d))) ; simpl ; auto.
Qed.
Definition facAux (fac:nat -> Delay nat) (n:nat) : Delay nat :=
match n with
| 0 => returnD 1
| S n' => mapD (fun m => n * m) (fac n')
end.
Definition fac : nat -> Delay nat := lfp facAux.
Eval compute in unfold_delay 6 (fac 5).
Lemma fixFacInd : forall (g:nat -> Delay nat) (n k:nat),
converges_to (lfpAux g facAux n) k ->
converges_to (lfpAux (facAux g) facAux (S n)) (S n * k).
Proof.
(* stuck! *)
Admitted.
Lemma facConverges : forall n, converges (fac n).
Proof.
unfold converges ; induction n.
exists 1.
rewrite (unfold_delay_id 1 (fac 0)) ; simpl ; auto.
elim IHn ; clear IHn ; intros m p.
exists (S n * m).
rewrite (unfold_delay_id 1 (fac (S n))) ; simpl (unfold_delay 1 (fac (S n))).
apply converges_later ; apply (fixFacInd _ _ p).
Qed.
- [Coq-Club] Termination proof in partiality monad, Edsko de Vries
- [Coq-Club] Re: [Agda] Termination proof in partiality monad,
Luke Palmer
Edsko de Vries
- Re: [Coq-Club] Re: [Agda] Termination proof in partiality monad,
Vladimir Komendantsky
Luke Palmer
- Re: [Coq-Club] Re: [Agda] Termination proof in partiality monad, Vladimir Komendantsky
- Re: [Coq-Club] Re: [Agda] Termination proof in partiality monad, Edsko de Vries
Luke Palmer
Edsko de Vries
- Message not available
- [Coq-Club] Agda beats Coq (was: Termination proof in partiality monad), Edsko de Vries
- [Coq-Club] Re: Agda beats Coq,
Nils Anders Danielsson
- [Coq-Club] Re: [Agda] Re: Agda beats Coq, Matthieu Sozeau
- [Coq-Club] Re: Agda beats Coq (was: Termination proof in partiality monad),
Dan Doel
- [Coq-Club] Re: Agda beats Coq, Nils Anders Danielsson
- Re: [Coq-Club] Re: Agda beats Coq (was: Termination proof in partiality monad), Aaron Bohannon
Luke Palmer
