- From: Ashish Darbari <ashish_darbariuk AT yahoo.co.uk>
- To: coq-club AT pauillac.inria.fr
- Cc: ashish AT darbari.org
- Subject: [Coq-Club] Finite Maps
- Date: Sun, 11 Jan 2009 18:58:44 +0000 (GMT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.co.uk; h=X-YMail-OSG:Received:X-Mailer:Date:From:Reply-To:Subject:To:Cc:MIME-Version:Content-Type:Message-ID; b=kowmQsnSrXU58A1afBIuzgEBM8g2VKO0dMu2wKhocqZzKVbvAQrvb6V4TCkzciT/oHAIgI0s4taws5YyC1kaSkIbCj9hKsfgd93iGq+n99lDz2fY6hBfHDgCuuS9RVG3B1+idkhEt4dExOMP+05OvgqAv+fNeYuMyvYruPY5je8=;
In my application I need to use an IntMap essentially a table of key-bindingsÂ
where keys are always (positive) integers, currently  in ocaml I use the followingÂ
module myMap = Map.Make
(struct type t = int
let compare = compare end);;
This exposes me to the full API for the IntMaps and I canÂ
use add, delete, find etc for it. I wanted to be able to getÂ
a similar if not exactly the same functionality from extraction in Coq. I'd
a look at the FMapAVL library and from the documentation it
appears that executing it in extracted world is reasonably fast.
(well as best as one gets from a Balanced Binary Tree)Â
I wanted to test the extracted ocaml code, so I did the following
to extract it in Coq 8.1pl4 :
Coq > Require Import FMapAVL.
Coq > Recursive Extraction Library FMapAVL.
and I get the following blurb:
The file logic.ml has been created by extraction.
The file logic.mli has been created by extraction.
The file datatypes.ml has been created by extraction.
The file fMapAVL.ml has been created by extraction.
The file fMapAVL.mli has been created by extraction.
However having compiled these using ocaml compilers and loading (#use)
the fMapAVL.ml I get an error messageÂ
The file ocaml and fMapList.cmi make inconsistent assumptions over interface List
How to fix this?Â
Is there an example somewhere I can see on how FMapAVL has been used
in practice for extraction? Can someone point me to any efficiency results for
the extracted FMaps in ocaml?
Thank you
Ashish
- [Coq-Club] Finite Maps, Ashish Darbari
- Re: [Coq-Club] Finite Maps,
Adam Chlipala
Stéphane Lescuyer
- Re: [Coq-Club] Finite Maps, Ashish Darbari
- [Coq-Club] Finite Maps - Installing Coq-8.2,
Ashish Darbari
- Re: [Coq-Club] Finite Maps - Installing Coq-8.2,
Yves Bertot
- Re: [Coq-Club] Finite Maps - Installing Coq-8.2, Benjamin Werner
Ashish Darbari
Jean-Marc Notin
- Re: [Coq-Club] Finite Maps - Installing Coq-8.2, Ashish Darbari
Jean-Marc Notin
Yves Bertot
Stéphane Lescuyer
Adam Chlipala
