- To: Ashish Darbari <ashish AT darbari.org>
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Finite Maps - Installing Coq-8.2
- Date: Mon, 12 Jan 2009 13:19:19 +0100
Ashish Darbari wrote:
Hi Fellows,I remember having a similar problem, but I don't remember how I fixed it. I believe that somehow, your compiler is using camlp4 instead of camlp5. Can you send us (or me) the
I tried building Coq-8.2 and it fails. Any clue?
I've a Mac OSX Darwin, ocaml-3.10.2 and camlp5-5.10
both successfully installed from sources.
Thanks
Ashish
Prayag:/usr/local/coq-8.2beta4 root# make world
****************** Entering stage1 ******************
make -f Makefile.stage1 "stage1"
make[1]: Entering directory `/usr/local/coq-8.2beta4'
OCAMLC4 lib/compat.ml4
File "lib/compat.ml4", line 17, characters 11-25:
Unbound type constructor Stdpp.location
make[1]: *** [lib/compat.cmo] Error 2
make[1]: Leaving directory `/usr/local/coq-8.2beta4'
make: *** [stage1] Error 2
text produced by the "configure" command in the coq root directory.
The following command should not fail:
ls $(ocamlc -where)/camlp5/stdpp.*
should succeed and find three files (.cmi .cmx .mli)
Yves
- [Coq-Club] Finite Maps, Ashish Darbari
- Re: [Coq-Club] Finite Maps,
Adam Chlipala
Stéphane Lescuyer
- Re: [Coq-Club] Finite Maps, Ashish Darbari
- [Coq-Club] Finite Maps - Installing Coq-8.2,
Ashish Darbari
- Re: [Coq-Club] Finite Maps - Installing Coq-8.2, Yves Bertot
- Re: [Coq-Club] Finite Maps - Installing Coq-8.2, Benjamin Werner
Ashish Darbari
Jean-Marc Notin
- Re: [Coq-Club] Finite Maps - Installing Coq-8.2, Ashish Darbari
Jean-Marc Notin
Stéphane Lescuyer
Adam Chlipala
