- From: Jean-Marc Notin <notin AT lix.polytechnique.fr>
- To: Ashish Darbari <ashish AT darbari.org>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Finite Maps - Installing Coq-8.2
- Date: Mon, 12 Jan 2009 14:52:41 +0100
- Organization: LIX - CNRS
Ashish Darbari a écrit :
Hi Yves,
Thank you for your response.
The output of the commands you requested:
Prayag:/usr/local/coq-8.2beta4 root# ls $(ocamlc -where)/camlp5/stdpp.*
/usr/local/ocaml-3.10.2/lib/camlp5/stdpp.cmi
/usr/local/ocaml-3.10.2/lib/camlp5/stdpp.mli
For my installation here is what I do:
Prayag:/usr/local/coq-8.2beta4 root# ./configure -camldir
/usr/local/ocaml-3.10.2/bin -camlp5dir /usr/local/camlp5-5.10/main
What I understand about your installation is that /usr/local/camlp5-5.10/ is the source directory for Camlp5,
not the installation directory. You should try to reinstall properly Camlp5, and re-configure Coq with the appropriate path:
In /usr/local/camlp5-5.10/, execute:
./configure -transitional -prefix usr/local/ocaml-3.10.2/ (it will install camlp5 in the the directories as OCaml)
make world.opt
make install
In usr/local/coq-8.2beta4, execute:
./configure -camldir /usr/local/ocaml-3.10.2/bin
(the configure script should find Camlp5 in the OCaml standard directory. If not try ./configure -camldir /usr/local/ocaml-3.10.2/bin -camlp5dir /usr/local/ocaml-3.10.2/lib/ocaml/camlp5/)
And then:
make world
I hope this could help...
Jean-Marc Notin
CNRS - LIX
smime.p7s
Description: S/MIME Cryptographic Signature
- [Coq-Club] Finite Maps, Ashish Darbari
- Re: [Coq-Club] Finite Maps,
Adam Chlipala
Stéphane Lescuyer
- Re: [Coq-Club] Finite Maps, Ashish Darbari
- [Coq-Club] Finite Maps - Installing Coq-8.2,
Ashish Darbari
- Re: [Coq-Club] Finite Maps - Installing Coq-8.2,
Yves Bertot
- Re: [Coq-Club] Finite Maps - Installing Coq-8.2, Benjamin Werner
Ashish Darbari
- Re: [Coq-Club] Finite Maps - Installing Coq-8.2, Jean-Marc Notin
- Re: [Coq-Club] Finite Maps - Installing Coq-8.2, Ashish Darbari
Yves Bertot
Stéphane Lescuyer
Adam Chlipala
