coq-club - [Coq-Club] Finite Maps - Installing Coq-8.2
chronological Thread
  • From: Ashish Darbari <ashish_darbariuk AT yahoo.co.uk>
  • To: coq-club AT pauillac.inria.fr
  • Cc: Ashish Darbari <ashish AT darbari.org>
  • Subject: [Coq-Club] Finite Maps - Installing Coq-8.2
  • Date: Mon, 12 Jan 2009 10:39:55 +0000 (GMT)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.co.uk; h=X-YMail-OSG:Received:X-Mailer:References:Date:From:Reply-To:Subject:To:Cc:MIME-Version:Content-Type:Message-ID; b=lY60mizSprNLCVIEmGLqEehS5jIWpY+mtl/D7+KVmpoOkApv7jaCc75MSXbR6A8ys2thDt8zHvc+ZT8EFKgzvVOhCv0sbdNp9lqFB6Ic7G3R/sD1tO7QzlUtkMjTpfXyyKLMjAo7IE9nEkFwNwqexpr9I44pc5FfT2HWxtOSBt4=;
Hi Fellows,
I tried building Coq-8.2 and it fails. Any clue?
I've a Mac OSX Darwin, ocaml-3.10.2 and camlp5-5.10
both successfully installed from sources.
Thanks
Ashish
Prayag:/usr/local/coq-8.2beta4 root# make world
****************** Entering stage1 ******************
make -f Makefile.stage1 "stage1"
make[1]: Entering directory `/usr/local/coq-8.2beta4'
OCAMLC4   lib/compat.ml4
File "lib/compat.ml4", line 17, characters 11-25:
Unbound type constructor Stdpp.location
make[1]: *** [lib/compat.cmo] Error 2
make[1]: Leaving directory `/usr/local/coq-8.2beta4'
make: *** [stage1] Error 2
To: Adam Chlipala <adamc AT hcoop.net>
Cc: Ashish Darbari <ashish AT darbari.org>; coq-club AT pauillac.inria.fr
Sent: Sunday, 11 January, 2009 19:22:28
Subject: Re: [Coq-Club] Finite Maps
There was indeed a discussion about this issue earlier in December and
Pierre Letouzey pointed to a new command
Extraction Blacklist <module name> .... .
that forces the extraction mechanism to rename modules like List and
String, in order to avoid clashes with the usual OCaml modules.
That would solve your issue without resorting to -pack (or worse, to sed).
It is only available in the svn snapshot or the current 8.2 beta version though.
HTH,
Stéphane L.
On Sun, Jan 11, 2009 at 8:12 PM, Adam Chlipala <adamc AT hcoop.net> wrote:
> Ashish Darbari wrote:
>> However having compiled these using ocaml compilers and loading (#use)
>> the fMapAVL.ml I get an error message
>> The file ocaml and fMapList.cmi make inconsistent assumptions over
>> interface List
> I expect that you extracted a file list.ml, which conflicts with [List] from
> the OCaml standard library.  Check out the [-pack] option to the OCaml
> compilers for a way to put your extracted modules in a separate namespace
> and avoid the clash.
> Bug reports: http://logical.futurs.inria.fr/coq-bugs
> Archives: http://pauillac.inria.fr/pipermail/coq-club
>        http://pauillac.inria.fr/bin/wilma/coq-club
> Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
I'm the kind of guy that until it happens, I won't worry about it. -
R.H. RoY05, MVP06
