- From: Ashish Darbari <ashish_darbariuk AT yahoo.co.uk>
- To: Yves Bertot <Yves.Bertot AT sophia.inria.fr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Finite Maps - Installing Coq-8.2
- Date: Mon, 12 Jan 2009 13:10:29 +0000 (GMT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.co.uk; h=X-YMail-OSG:Received:X-Mailer:References:Date:From:Reply-To:Subject:To:Cc:MIME-Version:Content-Type:Message-ID; b=jkg/P7hRq2FiTXdmS6vBXLp/pxMYqEgKIfgWEBJ8fuxKeB87WKEVdZrC6CxHzjfoQ6tLYlBWHsnLC9pP+9ODDW1ePNO5ekIt0pRAy3otrwrNktmhKpcyaJgLJ27cvw/DsivRpgnDtbLuJH+V9wTgSdyYz4LJEuQscC9CKONvkFo=;
Hi Yves,
Thank you for your response.
The output of the commands you requested:
Prayag:/usr/local/coq-8.2beta4 root# ls $(ocamlc -where)/camlp5/stdpp.*
/usr/local/ocaml-3.10.2/lib/camlp5/stdpp.cmi   /usr/local/ocaml-3.10.2/lib/camlp5/stdpp.mli
Prayag:/usr/local/coq-8.2beta4 root#Â
For my installation here is what I do:
I type this:
Prayag:/usr/local/coq-8.2beta4 root# ./configure -camldir /usr/local/ocaml-3.10.2/bin -camlp5dir /usr/local/camlp5-5.10/main
and I get  the following:
You have GNU Make 3.81. Good!
You have Objective-Caml 3.10.2. Good!
LablGtk2 not found: CoqIde will not be available.
hevea was not found: documentation will not be
available
Where should I install the Coq binaries [/usr/local/bin] ?
/usr/local/coq-8.2beta4/bin
Where should I install the Coq library [/usr/local/lib/coq] ?
/usr/local/coq-8.2beta4/lib
Where should I install the Coq man pages [/usr/local/man] ?
Where should I install the Coq documentation [/usr/local/share/doc] ?
Where should I install the Coq Emacs mode [/usr/local/share/emacs/site-lisp] ?
Where should I install Coqdoc TeX/LaTeX files [/usr/local/share/texmf/tex/latex/misc] ?
  Coq top directory         : /usr/local/coq-8.2beta4
  Architecture            : i386
  OS dependent libraries       : -cclib -lunix
  Objective-Caml/Camlp4 version   : 3.10.2
  Objective-Caml/Camlp4 binaries in :
  Objective-Caml library in     : /usr/local/ocaml-3.10.2/lib
  Camlp4 library in         : /usr/local/camlp5-5.10/main
  FSets theory            : All
  Reals theory            : All
  Documentation           : None
  CoqIde               : no
  Web browser            : firefox -remote "OpenURL(%s,new-tab)" || firefox %s &
  Paths for true installation:
   binaries    will be copied in /usr/local/coq-8.2beta4/bin
   library    will be copied in /usr/local/coq-8.2beta4/lib
   man pages   will be copied in /usr/local/man
   documentation will be copied in /usr/local/man
   emacs mode   will be
copied in /usr/local/share/emacs/site-lisp
If anything in the above is wrong, please restart './configure'
*Warning* To compile the system for a new architecture
      don't forget to do a 'make archclean' before './configure'.
Prayag:/usr/local/coq-8.2beta4 root# ./configure  -camlp5dir /usr/local/camlp5-5.10/main
After this when I do make world I get
CAMLP4DEPS contrib/cc/g_congruence.ml4
rm contrib/xml/xml.ml tactics/tauto.ml tactics/class_tactics.ml parsing/g_prim.ml contrib/xml/proofTree2Xml.ml tools/coq_makefile.ml toplevel/whelp.ml contrib/romega/g_romega.ml parsing/g_ltac.ml
contrib/cc/g_congruence.ml parsing/q_coqast.ml contrib/xml/xmlentries.ml lib/compat.ml parsing/q_constr.ml contrib/setoid_ring/newring.ml contrib/subtac/g_eterm.ml tactics/extraargs.ml contrib/subtac/g_subtac.ml parsing/g_decl_mode.ml contrib/interface/centaur.ml tools/coq-tex.ml contrib/omega/g_omega.ml contrib/rtauto/g_rtauto.ml parsing/vernacextend.ml contrib/micromega/g_micromega.ml contrib/field/field.ml contrib/ring/g_quote.ml tactics/hipattern.ml parsing/g_tactic.ml parsing/g_constr.ml contrib/interface/debug_tac.ml contrib/firstorder/g_ground.ml parsing/pcoq.ml parsing/tacextend.ml contrib/funind/g_indfun.ml contrib/extraction/g_extraction.ml parsing/g_xml.ml lib/pp.ml tactics/eauto.ml tactics/extratactics.ml parsing/g_vernac.ml contrib/interface/line_parser.ml parsing/argextend.ml parsing/lexer.ml parsing/q_util.ml toplevel/mltop.ml contrib/xml/acic2Xml.ml contrib/ring/g_ring.ml contrib/fourier/g_fourier.ml contrib/jprover/jprover.ml
contrib/xml/dumptree.ml tactics/eqdecide.ml parsing/g_proofs.ml contrib/dp/g_dp.ml
make[1]: Leaving directory `/usr/local/coq-8.2beta4'
make[1]: Entering directory `/usr/local/coq-8.2beta4'
OCAMLC Â Â config/coq_config.mli
OCAMLC Â Â lib/pp_control.mli
OCAMLC Â Â lib/pp.mli
OCAMLC4 Â lib/pp.ml4
OCAMLC4 Â lib/compat.ml4
File "lib/compat.ml4", line 17, characters 11-25:
Unbound type constructor Stdpp.location
make[1]: *** [lib/compat.cmo] Error 2
make: *** [stage1] Error 2
- [Coq-Club] Finite Maps, Ashish Darbari
- Re: [Coq-Club] Finite Maps,
Adam Chlipala
Stéphane Lescuyer
- Re: [Coq-Club] Finite Maps, Ashish Darbari
- [Coq-Club] Finite Maps - Installing Coq-8.2,
Ashish Darbari
- Re: [Coq-Club] Finite Maps - Installing Coq-8.2,
Yves Bertot
- Re: [Coq-Club] Finite Maps - Installing Coq-8.2, Benjamin Werner
- Re: [Coq-Club] Finite Maps - Installing Coq-8.2, Ashish Darbari
Jean-Marc Notin
Jean-Marc Notin
Yves Bertot
Stéphane Lescuyer
Adam Chlipala
