- To: Matej Kosik <kosik AT fiit.stuba.sk>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] A question concerning certain variant of the Prod rule
- Date: Wed, 15 Apr 2009 13:51:58 +0200
Hello Matej
There are many trivial functions you can define from types of kind
Prop to types of kind Set, for example
fun x:True => 3 : True -> nat
Unfortunately, for more interesting functions you run into a famous
problem: the "elimination of Prop into Set problem" discussed a certain
number of times on this mailing list. For reasons related to proof
irrelevance, it is illegal to de-construct an inductive term of type
P:Prop in order to contruct a term of type S:Set. This, as well as a
certain number of possible solutions, is discussed in the Coq'Art book
in section 14.2 (p394).
As an example, take the sample coq code:
Require Import List.
Variable A:Set.
Inductive not_empty:list A -> Prop:=
|ne_cons: forall a l, not_empty (a::l).
Variable l:list A.
Definition safe_head: not_empty l -> A.
intros.
destruct H.
exact a.
Defined.
This fails at "destruct H" for exactly this reason. This is why it is
difficult to define functions of type A->B, with A:Prop and B:Set.
Cheers,
Cody
On Wed, 2009-04-15 at 12:35 +0200, Matej Kosik wrote:
> Hello,
> I have started to read the Coq-book
> (Interactive Theorem Proving and Program Development)
> The general shape of the Prod(s,s',s'') rule is stated
> on page 91 as:
> E,Γ |- A:s E,Γ::(a:A) |- B:s'
> E,Γ ⊦ ∀a:A,B:s''
> One of the trivial cases whose description was left out from the book is
> this:
> s = Prop
> s' = s'' = Set
> E,Γ |- A:Prop E,Γ::(a:A) |- B:Set
> E,Γ |- ∀a:A,B:Set
> or perhaps the special case were
> `a' does not occur free in `B':
> E,Γ |- A:Prop E,Γ |- B:Set
> E,Γ |- A->B:Set
> Is it possible to give some meaningful examples of terms that can be
> constructed this way?
> Thanks in advance for advice.
> Bug reports: http://logical.saclay.inria.fr/coq-bugs
> Archives: http://pauillac.inria.fr/pipermail/coq-club
> http://pauillac.inria.fr/bin/wilma/coq-club
> Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] A question concerning certain variant of the Prod rule, Matej Kosik
- Re: [Coq-Club] A question concerning certain variant of the Prod rule,
Edsko de Vries
- Re: [Coq-Club] A question concerning certain variant of the Prod rule, Frederic Blanqui
- Re: [Coq-Club] A question concerning certain variant of the Prod rule, Edsko de Vries
- Re: [Coq-Club] A question concerning certain variant of the Prod rule, Cody Roux
- RE: [Coq-Club] A question concerning certain variant of the Prod rule, Kouskoulas, Yanni A.
- Re: [Coq-Club] A question concerning certain variant of the Prod rule, Yves Bertot
Edsko de Vries
