- To: Frederic Blanqui <frederic.blanqui AT inria.fr>
- Cc: Edsko de Vries <Edsko.de.Vries AT cs.tcd.ie>, Matej Kosik <kosik AT fiit.stuba.sk>, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] A question concerning certain variant of the Prod rule
- Date: Thu, 16 Apr 2009 12:28:06 +0200
Frederic Blanqui wrote:
Edsko de Vries a écrit :
or perhaps the special case were
`a' does not occur free in `B':
E,Γ |- A:Prop E,Γ |- B:Set
E,Γ |- A->B:Set
Is it possible to give some meaningful examples of terms that can be
constructed this way?
Such functions are valid only in special cases; in particular, it is possible to use a proof as argument to a function that returns an argument in Set if the proof is used *only* to guard termination of the function, but cannot otherwise influence the value returned. If you are working through Coq'Art, you'll get to such functions eventually: Sections 14.2.3 and 15.2.
Could someone give bibliographic references about this limitation?
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
I think this topic evolves far beyond Matej's initial question. There are only very few links between typing the prod-rule and general recursion as handled in the chapters cited by Edsko. Concentrating
on chaps. 4 to 9 is probably more productive for Matej.
The rest of this message is for Edsko and Frédéric.
From what I understood of Coq, there is no specific mechanism that takes care of verifying that pattern-matching is only used to ensure termination. What is used in general recursion is a combination of the following three features of the theory of inductive types in Coq:
- Pattern-matching is allowed on any Prop if what you need to produce is in sort Prop.
- Structural guardedness is verified modulo beta-iota-zeta-delta-reduction.
- An expression is a legitimate argument for a structural recursive guarded call if it is a variable (or the output of a function given as a a variable) obtained through pattern-matching from the recursive function's main argument, or if it is a pattern-matching expression where all branches are (recursively) legitimate arguments for a structural recursive guarded call.
* in particular, (p. 399), Acc_inv A R x H y Hr is structurally smaller than H, this expression is a legitimate argument for a structural recursive call if H is the principal argument of the recursive function (as in Acc_iter).
* Moreover, the type of
is
Acc R y ,
this type is in sort Prop, so the first feature applies.
This combination of features can be used in an even more clever way. There is a message by Christine Paulin on August 19, 2002 where this is explained (entitled "Re: How widely applicable is Coq? (beginner)"). Chap. 15.4 is a re-formulation of the technique.
If you plan to read section 14.2.2, please note that there are errors in the book, the corrections are given
at http://www.labri.fr/perso/casteran/CoqArt/induc-fond/index.html
Yves
- [Coq-Club] A question concerning certain variant of the Prod rule, Matej Kosik
- Re: [Coq-Club] A question concerning certain variant of the Prod rule,
Edsko de Vries
Frederic Blanqui
- Re: [Coq-Club] A question concerning certain variant of the Prod rule, Yves Bertot
- Re: [Coq-Club] A question concerning certain variant of the Prod rule, Edsko de Vries
- Re: [Coq-Club] A question concerning certain variant of the Prod rule, Frederic Blanqui
Frederic Blanqui
- Re: [Coq-Club] A question concerning certain variant of the Prod rule, Cody Roux
- RE: [Coq-Club] A question concerning certain variant of the Prod rule, Kouskoulas, Yanni A.
Edsko de Vries
