coq-club - Re: [Coq-Club] A question concerning certain variant of the Prod rule
chronological Thread
  • From: Frederic Blanqui <frederic.blanqui AT inria.fr>
  • To: Yves Bertot <Yves.Bertot AT sophia.inria.fr>
  • Cc: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] A question concerning certain variant of the Prod rule
  • Date: Fri, 17 Apr 2009 09:30:26 +0800
Thank you Yves for your remark about termination. But my question was not exactly about that. It was about the theoretical justification of what is described in coq-8.2-refman/Reference-Manual006.html. I cannot remember in which paper this is explained :-(
------------------coq-8.2-refman/Reference-Manual006.html:
The case of Inductive definitions of sort Prop is a bit more complicated, because of our interpretation of this sort. The only harmless allowed elimination, is the one when predicate P is also of sort Prop.
Prop
    [I:Prop|I→Prop]
Prop is the type of logical propositions, the proofs of properties P in Prop could not be used for computation and are consequently ignored by the extraction mechanism. Assume A and B are two propositions, and the logical disjunction A∨ B is defined inductively by :
Coq < Inductive or (A B:Prop) : Prop :=
Coq <   lintro : A -> or A B | rintro : B -> or A B.
The following definition which computes a boolean value by case over the proof of or A B is not accepted :
Coq < Definition choice (A B: Prop) (x:or A B) :=
Coq <    match x with lintro a => true | rintro b => false end.
Coq < Coq < Error:
Incorrect elimination of "x" in the inductive type "or":
the return type has sort "Set" while it should be "Prop".
Elimination of an inductive object of sort Prop
is not allowed on a predicate in sort Set
because proofs can be eliminated only to build proofs.
From the computational point of view, the structure of the proof of (or A B) in this term is needed for computing the boolean value.
In general, if I has type Prop then P cannot have type I→ Set, because it will mean to build an informative proof of type (P m) doing a case analysis over a non-computational object that will disappear in the extracted program. But the other way is safe with respect to our interpretation we can have I a computational object and P a non-computational one, it just corresponds to proving a logical property of a computational object.
In the same spirit, elimination on P of type I→ Type cannot be allowed because it trivially implies the elimination on P of type I→ Set by cumulativity. It also implies that there is two proofs of the same property which are provably different, contradicting the proof-irrelevance property which is sometimes a useful axiom :
Coq < Axiom proof_irrelevance : forall (P : Prop) (x y : P), x=y.
proof_irrelevance is assumed
The elimination of an inductive definition of type Prop on a predicate P of type I→ Type leads to a paradox when applied to impredicative inductive definition like the second-order existential quantifier exProp defined above, because it give access to the two projections on this type.
Empty and singleton elimination
There are special inductive definitions in Prop for which more eliminations are allowed.
Prop-extended
    I  is an empty or singleton definition   s ∈  S
    [I:Prop|I→ s]
A singleton definition has only one constructor and all the arguments of this constructor have type Prop. In that case, there is a canonical way to interpret the informative extraction on an object in that type, such that the elimination on any sort s is legal. Typical examples are the conjunction of non-informative propositions and the equality. If there is an hypothesis h:a=b in the context, it can be used for rewriting not only in logical propositions but also in any type.
Coq < Print eq_rec.
eq_rec =
fun (A : Type) (x : A) (P : A -> Set) => eq_rect x P
     : forall (A : Type) (x : A) (P : A -> Set),
       P x -> forall y : A, x = y -> P y
Argument A is implicit
Argument scopes are [type_scope _ _ _ _ _]
Coq < Extraction eq_rec.
(** val eq_rec : ’a1 -> ’a2 -> ’a1 -> ’a2 **)
let eq_rec x f y =
  f
An empty definition has no constructors, in that case also, elimination on any sort is allowed.
