coq-club - Re: [Coq-Club] A question concerning certain variant of the Prod rule
chronological Thread
  • To: Yves Bertot <Yves.Bertot AT sophia.inria.fr>
  • Cc: Frederic Blanqui <frederic.blanqui AT inria.fr>, Matej Kosik <kosik AT fiit.stuba.sk>, coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] A question concerning certain variant of the Prod rule
  • Date: Thu, 16 Apr 2009 11:47:12 +0100
Hi Yves,
From what I understood of Coq, there is no specific mechanism that takes care of verifying that pattern-matching is only used to ensure termination. What is used in general recursion is a combination of the following three features of the theory of inductive types in Coq:
- Pattern-matching is allowed on any Prop if what you need to produce is in sort Prop.
- Structural guardedness is verified modulo beta-iota-zeta-delta- reduction.
- An expression is a legitimate argument for a structural recursive guarded call if it is a variable (or the output of a function given as a a variable) obtained through pattern-matching from the recursive function's main argument, or if it is a pattern-matching expression where all branches are (recursively) legitimate arguments for a structural recursive guarded call.
* in particular, (p. 399), Acc_inv A R x H y Hr is structurally smaller than H, this expression is a legitimate argument for a structural recursive call if H is the principal argument of the recursive function (as in Acc_iter).
* Moreover, the type of
is
           Acc R y ,
this type is in sort Prop, so the first feature applies.
This combination of features can be used in an even more clever way. There is a message by Christine Paulin on August 19, 2002 where this is explained (entitled "Re: How widely applicable is Coq? (beginner)"). Chap. 15.4 is a re-formulation of the technique.
Thanks for clarifying that. Indeed, I had thought that there should be an additional bullet point to deal with the "special case" I mentioned earlier. What you are saying makes perfect sense, and simplifies my view of the world :)
Thanks again,
Edsko
