coq-club - Re: [Coq-Club] what are "levels" in Coq
chronological Thread
  • To: harke AT cs.pdx.edu
  • Cc: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] what are "levels" in Coq
  • Date: Tue, 6 Oct 2009 14:19:43 -0400
A related question: does Cow has an "internal representation" language with a more rigid syntactic structure?
V.
On Oct 6, 2009, at 2:11 PM,
harke AT cs.pdx.edu
 wrote:
This is a standard trick for reducing the amount of parenthesisation
used by many languages that have user defined infix operators.
You'll also notice the line:
 Reserved Notation "x /\ y" (at level 80, right associativity).
Try the following in coqide/proofgeneral:
 Variables A B C : Prop.
 Check A /\ (B <-> C).
 Check (A /\ B) <-> C.
You'll see the printout of the first shows parentheses while the second
omits them.  This is due to the different levels.  Then try:
 Check (A /\ B) /\ C.
 Check A /\ (B /\ C).
Again, the first shows parens, the second omits, due to the right
associativity.
On Tue, Oct 06, 2009 at 01:52:21PM -0400, Vladimir Voevodsky wrote:
Hi,
I am trying to understand the way in which Coq treats input texts. To
some extent it is explained in the first part of the reference manual,
but I could not find the explanation for what "levels" are (e.g. in
Reserved Notation "x <-> y" (at level 95, no associativity).
from the Coq standard library,)
Also, is there a way to search the reference manual?
Thanks,
Vladimir.
Tom Harke
