coq-club - Re: [Coq-Club] what are "levels" in Coq
chronological Thread
  • Cc: Vladimir Voevodsky <vladimir AT ias.edu>, Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] what are "levels" in Coq
  • Date: Wed, 07 Oct 2009 13:58:38 +0200
Thorsten Altenkirch wrote:
On 6 Oct 2009, at 19:19, Vladimir Voevodsky wrote:
A related question: does Cow has an "internal representation" language with a more rigid syntactic structure?
V.
I guess your question is more about using a simpler notation than the one with infix operators and all the special notations. The answer is yes. In principle, there is a very small language in which you can express all formulas of Coq. It is basically a lambda calculus, so that you write:
f a  (representing function application)
fun (x : type) => a (representing abstraction)
for expressions,
and :
forall (x : type), type
for types. Of course, function applications and abstractions can occur in types.
To be complete, you also need to understand the syntax of pattern-matching constructs:
match e as x in e' return e'' with p1 => e1 | ... end
the patterns p1, ..., mostly look like symbols and function applications.
For inputing data into Coq, this is basically all the syntax you need to know for terms. All the rest is decoration, and is defined using Notation.
There is one special treatment with numerals, but even them can be entered using a function notation.
For example, when understood as an integer (i.e., in Z_scope) 3 stands for Zpos (xO xH)
If you use only the syntax described here, you don't need to understand the notion of levels...
To know what function is hidden behind a notation, you can use Locate, as in the following example:
Locate "_ /\ _".
The answer that the function is actually named 'and', so that A /\ B can also be written (and A B).
I hope this helps.
Yves
