- To: hugo.herbelin AT inria.fr
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Type hierarchy
- Date: Sat, 10 Oct 2009 17:07:47 -0400
wrote:
On the other side, with Nat defined polymorphically in impredicative
Set (with option -impredicative-set), you get a full recursor
"Nat_rec" and at least the computational expressiveness of system T
but you cannot derive 0<>1 (and the recursor has a bad complexity due
to the linear complexity of the predecessor).
Doesn't the unprovability of [0 <> 1] only arise from doing away with inductive types altogether? If we just single out [nat] to be defined with impredicative polymorphism, then [0 <> 1] seems to reduce simply to [false <> true], which [discriminate] proves.
- Re: [Coq-Club] what are "levels" in Coq, (continued)
- Re: [Coq-Club] what are "levels" in Coq, Adam Chlipala
harke
Vladimir Voevodsky
Thorsten Altenkirch
Yves Bertot
- Re: [Coq-Club] what are "levels" in Coq, Lionel Elie Mamane
- [Coq-Club] Type hierarchy,
Jean-Francois Dufourd
- Re: [Coq-Club] Type hierarchy, André Hirschowitz
- Re: [Coq-Club] Type hierarchy, Hugo Herbelin
- Re: [Coq-Club] Type hierarchy, Adam Chlipala
- Re: [Coq-Club] Type hierarchy, Jean-Francois Dufourd
Yves Bertot
- [Coq-Club] an inductive types question, Vladimir Voevodsky
- Re: [Coq-Club] an inductive types question, Adam Chlipala
- Re: [Coq-Club] an inductive types question, Vladimir Voevodsky
- Re: [Coq-Club] an inductive types question, Thorsten Altenkirch
Vladimir Voevodsky
- Re: [Coq-Club] an inductive types question, AUGER Cédric
