coq-club - Re: [Coq-Club] Type hierarchy
chronological Thread
  • From: Hugo Herbelin <herbelin AT pauillac.inria.fr>
  • To: Adam Chlipala <adamc AT hcoop.net>
  • Cc: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Type hierarchy
  • Date: Sun, 11 Oct 2009 18:49:20 +0200
On Sat, Oct 10, 2009 at 05:07:47PM -0400, Adam Chlipala wrote:
> hugo.herbelin AT inria.fr
>  wrote:
> > On the other side, with Nat defined polymorphically in impredicative
> > Set (with option -impredicative-set), you get a full recursor
> > "Nat_rec" and at least the computational expressiveness of system T
> > but you cannot derive 0<>1 (and the recursor has a bad complexity due
> > to the linear complexity of the predecessor).
> Doesn't the unprovability of [0 <> 1] only arise from doing away with
> inductive types altogether?  If we just single out [nat] to be defined
> with impredicative polymorphism, then [0 <> 1] seems to reduce simply to
> [false <> true], which [discriminate] proves.
Yes, I was assuming defining datatypes impredicatively in
isolation. In the given context of the Calculus of Inductive
Constructions, having "false <> true" for bool in Set indeed
propagates discrimination to the "constructors" of all the
impredicatively defined datatypes.
Hugo
