- To: Vladimir Voevodsky <vladimir AT ias.edu>
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] what are "levels" in Coq
- Date: Tue, 6 Oct 2009 20:17:50 +0100
On 6 Oct 2009, at 19:19, Vladimir Voevodsky wrote:
A related question: does Cow has an "internal representation" language with a more rigid syntactic structure?
V.
Coq is based on the Calculus of Inductive (and Coinductive) Constructions. This is a dependently typed lambda calculus with an impredicative universe (The Calculus of Constructions) of propositions extended by a predicative universe of sets which are closed under inductive (and coinductive) definitions. See the reference manual, the Coq'Art book and a number of related research papers and PhD theses.
Cheers,
Thorsten
On Oct 6, 2009, at 2:11 PM,
harke AT cs.pdx.edu
wrote:
This is a standard trick for reducing the amount of parenthesisation
used by many languages that have user defined infix operators.
You'll also notice the line:
Reserved Notation "x /\ y" (at level 80, right associativity).
Try the following in coqide/proofgeneral:
Variables A B C : Prop.
Check A /\ (B <-> C).
Check (A /\ B) <-> C.
You'll see the printout of the first shows parentheses while the second
omits them. This is due to the different levels. Then try:
Check (A /\ B) /\ C.
Check A /\ (B /\ C).
Again, the first shows parens, the second omits, due to the right
associativity.
On Tue, Oct 06, 2009 at 01:52:21PM -0400, Vladimir Voevodsky wrote:
Hi,
I am trying to understand the way in which Coq treats input texts. To
some extent it is explained in the first part of the reference manual,
but I could not find the explanation for what "levels" are (e.g. in
Reserved Notation "x <-> y" (at level 95, no associativity).
from the Coq standard library,)
Also, is there a way to search the reference manual?
Thanks,
Vladimir.
Tom Harke
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
This message has been checked for viruses but the contents of an attachment
may still contain software viruses, which could damage your computer system:
you are advised to perform your own checks. Email communications with the
University of Nottingham may be monitored as permitted by UK legislation.
- [Coq-Club] binary distribution for Leopard (and Snow Leopard), Thorsten Altenkirch
- Re: [Coq-Club] binary distribution for Leopard (and Snow Leopard),
Matthieu Sozeau
- [Coq-Club] what are "levels" in Coq,
Vladimir Voevodsky
- Re: [Coq-Club] what are "levels" in Coq, Adam Chlipala
harke
Vladimir Voevodsky
- Re: [Coq-Club] what are "levels" in Coq, Thorsten Altenkirch
Yves Bertot
- Re: [Coq-Club] what are "levels" in Coq, Lionel Elie Mamane
- [Coq-Club] Type hierarchy,
Jean-Francois Dufourd
- Re: [Coq-Club] Type hierarchy, André Hirschowitz
- Re: [Coq-Club] Type hierarchy, Hugo Herbelin
- Re: [Coq-Club] Type hierarchy, Adam Chlipala
- Re: [Coq-Club] Type hierarchy, Jean-Francois Dufourd
Yves Bertot
- [Coq-Club] an inductive types question, Vladimir Voevodsky
- Re: [Coq-Club] an inductive types question, Adam Chlipala
Vladimir Voevodsky
Vladimir Voevodsky
Matthieu Sozeau
