- To: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: [Coq-Club] More nested fixpoint difficulties.
- Date: Fri, 23 Oct 2009 16:06:50 -0400 (EDT)
On Wed, 21 Oct 2009, Robbert Krebbers wrote:
Unfortunately this does not work, the system gives the following error:
Error:
Recursive definition of trm_rec2 is ill-formed
Recursive call to avar_rec2 has principal argument equal to "a"
instead of a subterm of t
I have a simlar problem on a more complex data structure. Below I present what I hope is a simple (but silly) example that captures the problem I am having.
Require Import List.
Inductive tree (A:Type) :=
node : A -> list (tree A) -> tree A.
Section Foo.
Variables (A:Type) (P : tree A -> Prop) (Q: list (tree A) -> list (tree A) -> Prop).
Hypotheses
(H:forall (a:A) (l m:list (tree A)), Q l m -> P (node A a l))
(H0: forall l, Q nil l)
(H0': forall l, Q l nil)
(H1: forall t, P t -> forall s, P s -> forall l m, Q l m -> Q (cons t l) (cons s m)).
Section Z.
Hypothesis (tree_ind0 : forall t, P t).
Fixpoint Z (l : list (tree A)) (m:list (tree A)) : Q l m :=
match l as l return Q l m with
| nil => H0 m
| cons t l0 =>
match m as m return Q (cons t l0) m with
| nil => H0' (cons t l0)
| cons s m0 => H1 t (tree_ind0 t) s (tree_ind0 s) l0 m0 (Z l0 m0)
end
end.
End Z.
Fixpoint tree_ind0 (t:tree A) : P t :=
match t as x return P x with
(* Here I pass the same list twice to Z, but in my real
problem my "tree" type has two separate lists that
are processed in parallel *)
| node a l => H a l l (Z tree_ind0 l l)
end.
(* This Fixpoint definition fails with the message:
Recursive call to tree_ind0 has principal argument equal to "s"
instead of one of the following variables: l l0 t0 l1.
End Foo.
Essentially I have two lists as substructures of my structure (lists that contain further members of my structure (my structure is simply s-expressions)) that are to be processed in parallel to create the output.
When passing one list, the nested recursion works fine; however to process two lists in parallel I do recursion on one list, and decompose the other list as I go. However Coq doesn't seem to recognise that decompostion of the second list is a substructure.
Anyone have a solution to this type of problem?
For what it's worth, it seems that Agda can handle this case without difficulty. I've attached the Agda code.
Russell O'Connor <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''module tree2 where
data list (A : Set) : Set where
nil : list A
cons : A -> list A -> list A
data tree (A : Set) : Set where
module Foo (A : Set)
(P : tree A -> Set)
(Q : list (tree A) -> list (tree A) -> Set)
(H : (a : A) -> (l m : list (tree A)) -> Q l m -> P (node a l))
(H0 : (l : list (tree A)) -> Q nil l)
(H0' : (l : list (tree A)) -> Q l nil)
(H1 : (t : tree A) -> P t -> (s : tree A) -> P s ->
(l m : list (tree A)) -> Q l m -> Q (cons t l) (cons s m))
where
mutual
treeInd : (t : tree A) -> P t
treeInd (node y y') = H y y' y' (Z y' y')
Z : (l m : list (tree A)) -> Q l m
Z nil m = H0 m
Z (cons y y') nil = H0' ((cons y y'))
Z (cons y y') (cons y0 y1) = H1 y (treeInd y) y0 (treeInd y0) y' y1 (Z y'
y1)
- [Coq-Club] Meta theory: induction over terms with abstract variables, Robbert Krebbers
- Re: [Coq-Club] Meta theory: induction over terms with abstract variables, Adam Chlipala
- Re: [Coq-Club] Meta theory: induction over terms with abstract variables, Brian E. Aydemir
- Re: [Coq-Club] Meta theory: induction over terms with abstract variables, Hugo Herbelin
- [Coq-Club] More nested fixpoint difficulties., roconnor
- Re: [Coq-Club] More nested fixpoint difficulties., Adam Chlipala
