coq-club - Re: [Coq-Club] More nested fixpoint difficulties.
chronological Thread
  • To: roconnor AT theorem.ca
  • Cc: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] More nested fixpoint difficulties.
  • Date: Fri, 23 Oct 2009 17:01:42 -0400
 wrote:
Fixpoint Z (l : list (tree A)) (m:list (tree A)) : Q l m :=
match l as l return Q l m with
| nil => H0 m
| cons t l0 =>
  match m as m return Q (cons t l0) m with
  | nil => H0' (cons t l0)
  | cons s m0 => H1 t (tree_ind0 t) s (tree_ind0 s) l0 m0 (Z l0 m0)
  end
end.
End Z.
Fixpoint tree_ind0 (t:tree A) : P t :=
 match t as x return P x with
  (* Here I pass the same list twice to Z, but in my real
     problem my "tree" type has two separate lists that
     are processed in parallel *)
 | node a l => H a l l (Z tree_ind0 l l)
 end.
(* This Fixpoint definition fails with the message:
   Recursive call to tree_ind0 has principal argument equal to "s"
   instead of one of the following variables: l l0 t0 l1.
It's not surprising that this fails. Even though you don't need to write a termination annotation in the definition of [Z], Coq infers one for you. It has to pick one or the other of the two arguments. Whichever one it picks, the matching call to [tree_ind0] isn't structurally recursive. I think this comes down to the fundamental limitation that [Fixpoint] needs a termination argument based on just a single input. You could perhaps get around this by changing [Z] to take a pair as input, possibly also switching to [Function] instead of [Fixpoint].
