coq-club - Re: [Coq-Club] Properties on mutual definitions
chronological Thread
  • To: Thomas Thüm <thomas.thuem AT st.ovgu.de>, "'Coq Club'" <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Properties on mutual definitions
  • Date: Wed, 09 Dec 2009 18:10:13 +0100
  • Organization: ProVal
(* As replied by Adam, you want to produce and not to consume.
Furthermore, as I show below, you have not a lot of choice in your production
        (only identity works), and what you wanted to produce cannot be
produced
the way you thought as "exists l', g l l'" can never be structuraly inferior
to "f a a'", as you break the induction by the introduction of the "exists".
        Here is maybe what you wanted to have.
I never use Scheme or Combined Scheme (but I don't have opinions on whether
it is a good way or not to have mutual
                                               induction),
and I think that (when it is possible) using mutual Lemma is often a simpler
        to do what you want (I recognize it is not always the case as it is
less
                             powerful than Scheme & co.),
        as shown here.
Require Export List.
Inductive exp : Type :=
| e_var : nat -> exp
| e_meth : exp -> nat -> list exp -> exp.
(* For simplicity, only identical expression (lists of expressions) are in
the relation f (g). *)
Inductive f : exp -> exp -> Prop :=
| f_var : forall n,
    f (e_var n) (e_var n)
| f_meth : forall a a' l l' n,
    f a a' ->
    g l l' ->
    f (e_meth a n l) (e_meth a' n l')
with g : list exp -> list exp -> Prop :=
| g_nil :
    g nil nil
| g_cons : forall a a' l l',
    f a a' ->
    g l l' ->
    g (a::l) (a'::l').
Fact totalf :
    forall a a', f a a' -> a = a'
with totalg :
    forall l l', g l l' -> l = l'.
Proof.
 (* the totalf proof *)
 intros a a' H; destruct H as [n | a a' l l' n Ha Hl].
  reflexivity.
 rewrite (totalf a a' Ha).
 rewrite (totalg l l' Hl).
 reflexivity.
 (* the totalg proof *)
 intros l l' H; destruct H as [| a a' l l' Ha Hl].
  reflexivity.
 reflexivity.
Qed.
Le Wed, 09 Dec 2009 12:26:50 +0100, Thomas Thüm <thomas.thuem AT st.ovgu.de> a écrit:
Hi all,
I was wondering how to create a useful induction principle to prove
properties on mutual definitions. It is clear how to generate induction
principles for mutual definitions, but I cannot apply them in my case. I
could imagine to write an induction principle by hand, but hopefully there
is an automatic way?
Thanks,
Thomas
| e_var : nat -> exp
| f_var : forall n,
    f a a' ->
    g l l' ->
| g_nil :
    g nil nil
    f a a' ->
    g l l' ->
    g (a::l) (a'::l').
Scheme f_ind2 := Minimality for f Sort Prop
with g_ind2 := Minimality for g Sort Prop.
Combined Scheme fg_mutind from f_ind2, g_ind2.
Fact total :
    ( forall a, exists a', f a a' ) /\
    ( forall l, exists l', g l l' ).
Proof.
(* fg_mutind cannot be applied... *)
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
          http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
Cédric AUGER
Univ Paris-Sud, Laboratoire LRI, UMR 8623, F-91405, Orsay
