- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] How does the simpl. tactics behave?
- Date: Tue, 7 Sep 2010 07:04:10 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type; b=Pdx881sDmhj6lgTd8k6bSQR39+Lb3QlNBjhDKqge6GMWzKzSrVCDMdZ+NtON6hy2yq We2jX3qaDvxcf5Q2f3PJzKYyykCA1nQTC262p4qrk7NTKUkkZGWv5t2QOCbny5px/If6 h7aWlQ61W0B7SQKDs69qexY2cf9g2gSZJZO+I=
Thanks foe your answer.
According to the coq manual , sympl. did some kind of beta-iota conversion. With the fx defined as
lambda x. (forall x, 0)
I think if simpl. really does the beta-conversion, it should be doing like this:
( lambda x. (forall x, 0) ) 3
-->_beta (forall x, 0) [x<-3]
-->_beta 0
I do hope to know why simpl. does not give outr the result in this way?
Thanks for yorur ideas.
Zell.
On Mon, Sep 6, 2010 at 7:21 PM, Adam Chlipala <adam AT chlipala.net> wrote:
[simpl] never solves goals; it just simplifies them. The proof script from your second example proves your first example, too. In both cases, [simpl] can be left out, since [reflexivity] works modulo all legal simplifications that [simpl] might perform (and others that [simpl] will never perform).
Z wrote:
I find it strange this follwoing pretty simple proof does not work. Apparently, simpl. does not do the work. Someone would like to give me more ideas about this failure??
Definition fx (x:nat):nat := 0 .
Example test000: fx 3 = 0.
Proof. intros. simpl. Qed.
By contrary, this following proof goes well,
Inductive day:Type := |today : day |other: day.
Definition otherday (d: day): day := match d with |today => other |other=> today end.
Example test006: otherday today = other.
Proof. simpl. reflexivity. Qed.
[simpl] only unfolds definitions when doing so causes some [match] to simplify. I hope it's not hard to see the consequences of this heuristic for the two examples, and why it leads to the [simpl] behavior you see.
- [Coq-Club] How does the simpl. tactics behave?, Z
- Re: [Coq-Club] How does the simpl. tactics behave?,
Adam Chlipala
- Re: [Coq-Club] How does the simpl. tactics behave?, Z
Christine Paulin
- Message not available
Christine Paulin
- Re: [Coq-Club] How does the simpl. tactics behave?, Adam Chlipala
Adam Chlipala
