coq-club - Re: [Coq-Club] How does the simpl. tactics behave?
chronological Thread
  • To: Z <zell08v AT orange.fr>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] How does the simpl. tactics behave?
  • Date: Tue, 07 Sep 2010 12:14:42 -0400
Z wrote:
Here is another example that I have some trouble to understand, where simpl. does not want to unfold gx although it should have considered that "match"
Any ideas?
Definition gx(x: nat) := match x with |_ =>0 end.
Eval simpl gx in gx 0.
Here, the issue is that Coq programs that you type are elaborated into a simpler internal language. For your example, that elaboration includes replacing the [match] with its body, since you have just one pattern that binds no variables. You can see this by running [Print gx.].
Then, in this case, which tactic to do the unfolding work?
In many contexts, there is no need for unfolding.  For instance:
Goal forall x, gx x = 0.
  reflexivity.
Qed.
This works because at the lowest level of Coq's logic, equality is defined modulo unfolding. For more complicated cases where you need to massage the form of a goal to get other tactics to apply, you can always run [unfold gx] to unfold [gx] in the conclusion.
