coq-club - Re: [Coq-Club] How does the simpl. tactics behave?
chronological Thread
  • To: Z <zell08v AT orange.fr>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] How does the simpl. tactics behave?
  • Date: Tue, 07 Sep 2010 06:53:52 -0400
Z wrote:
With the fx defined as
lambda x. (forall x, 0)
I think if simpl. really does the beta-conversion, it should be doing like this:
( lambda x. (forall x, 0) ) 3
-->_beta (forall x, 0) [x<-3]
-->_beta 0
I do hope to know why simpl. does not give outr the result in this way?
On Mon, Sep 6, 2010 at 7:21 PM, Adam Chlipala <adam AT chlipala.net <mailto:adam AT chlipala.net>> wrote:
    [simpl] only unfolds definitions when doing so causes some [match]
    to simplify.  I hope it's not hard to see the consequences of this
    heuristic for the two examples, and why it leads to the [simpl]
    behavior you see.
To give an alternate answer to this question: Like I wrote above, [simpl] only unfolds definitions when doing so simplifies [match] expressions. Unfolding [fx] in [fx 3] does not produce a term containing a [match] expression, so it is not possible to simplify any [match] expression, so no unfolding is done by [simpl]. This is a completely mechanical procedure with no subtleties. Perhaps you are assuming that [simpl] must be "smarter" than it is; I expect your confusion will disappear if you can get over that assumption. ;)
Also, your reduction sequence above is incorrect. The final result should still contain a [forall], and there should only be one beta step.
