coq-club - Re: [Coq-Club] Re: Universe Polymorphism
chronological Thread
  • To: Dan Doel <dan.doel AT gmail.com>
  • Cc: coq-club AT inria.fr, Randy Pollack <rpollack AT inf.ed.ac.uk>, Benjamin Werner <benjamin.werner AT polytechnique.org>
  • Subject: Re: [Coq-Club] Re: Universe Polymorphism
  • Date: Tue, 14 Sep 2010 14:56:30 +0200
On Sep 13, 2010, at 5:47 PM, Dan Doel wrote:
 data T {i : Level} : Set (suc i) where
   t : Set i -> T
 u : forall {i} -> T {suc i}
 u = t T
I'm not sure how the Aczel set theory thing would work out. I suspect it would
fail earlier, or you'd only be able to prove that R i \in R (suc i) (depending
on how R was defined).
Level is almost an ordinary type---there's a little compiler support for
normalizing expressions like 'lub x x' to 'x' even for open terms; I think
this is in part due to Agda totaly lacking cumulativity, so lubs of multiple
levels variables need to be used instead of implicitly lifting everything
involved to a single level.
During the Agda meeting which finished a week ago we started to add cumulativity which makes things much more smooth in practice. Explicit lubs won't be needed anymore. Also level won't be an ordinary type anymore, it will be a version of the natural numbers you cannot compute on. This ensures that levels remain irrelevant for computation, they are only there to sort out the universe stratification. This is in analogy to sizes in the type-based termination approach: sizes are only there to sort out the termination, they are computationally irrelevant.
As of now, you can play with explicit universe polymorphism and cumulativity in MiniAgda (see my homepage). There your example looks like:
data T (i : Size) : Set $i
{ inn : (out : Set i) -> T i
fun U : (i : Size) -> T $i
{ U i = inn $i (T i)
MiniAgda-bug reports welcome!
Also, I believe the rule for universe polymorphic
functions is adequately described by:
 if U[x] : Set S, where x is free in S
 then ((x : T) -> U[x]) : Setω
Where ω is not itself a Level (and thus Setω is not itself of the form Set i
for some i : Level, which would probably be paradoxical).
This stuff isn't remotely well-established theoretically as far as I know,
though. At least, it's novel with respect to all the published papers I've
seen on universe polymorphism. So I could understand people being reluctant to
put it in Coq at this point.
I think with making levels non-computational it is not as scary any more. Of course the rule for universe-polymorphic function types above is still needed. However, it does not have to be a special rule. If you want to type check
  (x : Level) -> U[x] : ?
then ? cannot mention x, but continuing
  x : Level |- U[x] : ?
you need an upper bound for all the sorts (Set S[x]) and that can only be Setω. Note that Setω is not part of the Agda syntax, it is used only internally, and plays the role of "Type" in the Martin-L"of logical framework.
I think we have a systematic and fairly simple solution to the problem of universe polymorphism. It can be described as a PTS with cumulativity and subtyping in a straightforward manner. There is a cost in type checking due to an additional level argument in all universe-polymorphic definitions, but I hope to keep it low by adding Miquel/Barras/Bernardo-style irrelevance for level-polymorphic things.
--Andreas
Andreas Abel  <><      Du bist der geliebte Mensch.
Theoretical Computer Science, University of Munich
Oettingenstr. 67, D-80538 Munich, GERMANY
andreas.abel AT ifi.lmu.de
http://www2.tcs.ifi.lmu.de/~abel/
