- To: coq-club AT inria.fr
- Cc: Randy Pollack <rpollack AT inf.ed.ac.uk>, Benjamin Werner <benjamin.werner AT polytechnique.org>
- Subject: Re: [Coq-Club] Re: Universe Polymorphism
- Date: Mon, 13 Sep 2010 11:47:31 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=from:to:subject:date:user-agent:cc:references:in-reply-to :mime-version:content-type:content-transfer-encoding:message-id; b=orJxCWT0FiproAiYqlhVPh3hVUnrObX92y5HDG77AO46K7Ks1su0J59jMlZituGoPB xVFLgRCEaRg7L9ErlHBevjl+uyHfetQ1W3zI7loQGXDonk22q+gVQkg6eK6YMA56dEN5 09olhw/ErgB2RqP5wHRq6mj7P9aaLKIvKP0WQ=
On Monday 13 September 2010 9:05:42 am Randy Pollack wrote:
> It seems that Agda has some experimental feature of explicit
> (outermost?) quantification over universe levels that should be looked
> into.
I don't know what you mean by "outermost". But yes, it's quite simple to
encode T in Agda:
data T (i : Level) : Set (suc i) where
t : Set i -> T i
u : forall i -> T (suc i)
u i = t (T i)
I can even make the indices implicit so it'll look weird:
data T {i : Level} : Set (suc i) where
t : Set i -> T
u : forall {i} -> T {suc i}
u = t T
I'm not sure how the Aczel set theory thing would work out. I suspect it
would
fail earlier, or you'd only be able to prove that R i \in R (suc i)
(depending
on how R was defined).
Level is almost an ordinary type---there's a little compiler support for
normalizing expressions like 'lub x x' to 'x' even for open terms; I think
this is in part due to Agda totaly lacking cumulativity, so lubs of multiple
levels variables need to be used instead of implicitly lifting everything
involved to a single level. Also, I believe the rule for universe polymorphic
functions is adequately described by:
if U[x] : Set S, where x is free in S
then ((x : T) -> U[x]) : Setω
Where ω is not itself a Level (and thus Setω is not itself of the form Set i
for some i : Level, which would probably be paradoxical).
This stuff isn't remotely well-established theoretically as far as I know,
though. At least, it's novel with respect to all the published papers I've
seen on universe polymorphism. So I could understand people being reluctant
to
put it in Coq at this point.
-- Dan
- Universe Polymorphism (Was: [Coq-Club] Proving eq_dep statements?), David Leduc
- Re: Universe Polymorphism (Was: [Coq-Club] Proving eq_dep statements?),
Bruno Barras
David Leduc
Benjamin Werner
- [Coq-Club] Re: Universe Polymorphism,
Randy Pollack
- Re: [Coq-Club] Re: Universe Polymorphism, Dan Doel
Randy Pollack
Andreas Abel
- Re: [Coq-Club] Re: Universe Polymorphism, David Leduc
- Re: [Coq-Club] Re: Universe Polymorphism, Andreas Abel
Randy Pollack
Randy Pollack
Benjamin Werner
David Leduc
Bruno Barras
