coq-club - Re: [Coq-Club] Re: Universe Polymorphism
chronological Thread
  • To: David Leduc <david.leduc6 AT googlemail.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Re: Universe Polymorphism
  • Date: Thu, 16 Sep 2010 17:35:11 +0200
Hi David,
On Sep 14, 2010, at 3:49 PM, David Leduc wrote:
Andreas Abel
<andreas.abel AT ifi.lmu.de>
 wrote:
During the Agda meeting which finished a week ago we started to add
cumulativity
This looks like a very dynamic community!!
data T (i : Size) : Set $i
{ inn : (out : Set i) -> T i
I guess 'inn' is for the 't' in my example.
What is 'out'? Why do you need it?
This is MiniAgda code (which is slightly different from Agda in Syntax). From this declaration you get:
T : (i : Size) -> Set $i
inn : [i : Size] -> Set i -> T i
out : [i : Size] -> T i -> Set i
"out", the destructor, is not needed. Bracketed quantification [i : Size] -> ... is irrelevant quantification a la Barras/Bernardo (ICC).
fun U : (i : Size) -> T $i
{ U i = inn $i (T i)
I guess it's a function definition by case analysis (here the only
case is 'i'), right?
Yes, you could also write
  let U : (i : Size) -> T $i
    = \ i -> inn $i (T i)
I'm surprised by the $i in the type of U. Shouldn't it be the successor of $i???
It type-checks:
  T i : Set $i
  inn $i (T i) : T $i
$i means "successor of i".
Why do you pass two arguments to 'inn' while according to its
definition it appears to take only one?
MiniAgda's "data" is like the "Inductive" definition in Coq. The parameters (i:Size) are added to the constructor type.
Cheers,
Andreas
Andreas Abel  <><      Du bist der geliebte Mensch.
Theoretical Computer Science, University of Munich
Oettingenstr. 67, D-80538 Munich, GERMANY
http://www2.tcs.ifi.lmu.de/~abel/
