- To: Carsten Varming <varming AT cmu.edu>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] Interaction between Setoids and Canonical Structures
- Date: Mon, 13 Dec 2010 18:23:01 +0100
Hi,
On 13/12/2010 16:04, Carsten Varming wrote:
> The main problem is with the type class resolution.
> The type of eqT in
> the morphism declaration is (sort T), but the resolution algorithm is
> looking for (sort' (str_str' T)), and it doesn't know that (sort T)
> and (sort' (str_str' T)) are equal.
Thank you for this answer.
I tried to adapt your fix to the complete case, and now it works in the trivial cases. However, I still have issues each time the type of the arguments does not fit exactly the one I declared for the morphism. Here is a new reduced example of my problem.
Since (sort' (str_str' T)) and sort T are convertible, why does the resolution fail ?
Cheers,
Cyril Cohen
Require Import Relation_Definitions Setoid Morphisms.
Variable A : Type.
Structure str := Str { sort :> Type }.
Structure str' := Str' { sort' :> Type }.
Canonical Structure str_str' (T : str) := Str' T.
Structure str'' := Str'' { sort'' :> Type }.
Canonical Structure str_str'' (T : str) := Str'' T.
Canonical Structure str'_str'' (T : str') := Str'' T.
Variable eqT : forall T : str, T -> T -> Prop.
Variable op : forall T : str', T -> T.
Variable op' : forall T : str'', T -> T.
Add Parametric Relation (T : str) : T (eqT T)
reflexivity proved by _
symmetry proved by _
transitivity proved by _ as eqT_rel.
Proof. Admitted.
Add Parametric Morphism (T : str) : (op _ : T -> T)
with signature ((@eqT _ : sort' _ -> _ -> _) ==> @eqT _)%signature as eqT_op.
(* with signature (((@eqT _) : sort' (str_str' T) -> _ -> _) ==> @eq
_)%signature as eqT_op. *)
Admitted.
Add Parametric Morphism (T : str) : (op' _ : T -> T)
with signature ((@eqT _ : sort'' _ -> _ -> _) ==> @eqT _)%signature as
eqT_op'.
Admitted.
Print HintDb typeclass_instances.
Goal forall (T : str) (a b : T), eqT _ a b -> eqT _ (op _ a) (op _ b).
Proof.
intros T a b eab.
rewrite eab. (* success *)
Abort.
Goal forall (T : str) (a b : T), eqT _ a b -> eqT _ (op _ (op' _ a)) (op _
(op' _ b)).
Proof.
intros T a b eab.
Abort.
Goal forall (T : str) (a b : T), eqT _ a b -> eqT _ (op' _ (op _ a)) (op' _
(op _ b)).
Proof.
intros T a b eab.
rewrite eab. (* fail *)
Abort.
- [Coq-Club] Interaction between Setoids and Canonical Structures, Cyril Cohen
- Re: [Coq-Club] Interaction between Setoids and Canonical Structures,
Cyril Cohen
Carsten Varming
- Re: [Coq-Club] Interaction between Setoids and Canonical Structures, Cyril Cohen
- Re: [Coq-Club] Interaction between Setoids and Canonical Structures, Carsten Varming
Carsten Varming
Cyril Cohen
