- To: Carsten Varming <varming AT cmu.edu>
- Cc: Cyril Cohen <cohen AT crans.org>, Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Interaction between Setoids and Canonical Structures
- Date: Tue, 14 Dec 2010 19:18:55 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=sender:subject:mime-version:content-type:from:in-reply-to:date:cc :content-transfer-encoding:message-id:references:to:x-mailer; b=wUGQcDT4RFEwyQWytPqGzbCDdEJ3bIbymkHF9lGUoGUFoRTbQvVvhU1rtfZImkKnhZ 06sr8LoLSXFE42g9/6H6t+ydo+q8NxVa5lZemi/jrQSdeTHhtZfvftu1+akB0X65qTNt FOdJ/vAG71FVEYzm2deovrf8lPzqYnHTbIlFM=
Hi,
Le 14 déc. 2010 à 16:29, Carsten Varming a écrit :
> On Mon, 13 Dec 2010, Cyril Cohen wrote:
>> Hi,
>> On 13/12/2010 16:04, Carsten Varming wrote:
>>> The main problem is with the type class resolution.
>>> The type of eqT in
>>> the morphism declaration is (sort T), but the resolution algorithm is
>>> looking for (sort' (str_str' T)), and it doesn't know that (sort T)
>>> and (sort' (str_str' T)) are equal.
>> Thank you for this answer.
>> I tried to adapt your fix to the complete case, and now it works in the
>> trivial cases. However, I still have issues each time the type of the
>> arguments does not fit exactly the one I declared for the morphism. Here
>> is a new reduced example of my problem.
>> Since (sort' (str_str' T)) and sort T are convertible, why does the
>> resolution fail ?
> I don't know. You would think that evaluating types to a normal form would
> be the right thing to do, but that not the way it is currently done.
Let's simplify even a bit more:
Require Import Relation_Definitions.
Variable A : Type.
Structure str := Str { sort :> Type }.
Structure str' := Str' { sort' :> Type }.
Canonical Structure str_str' (T : str) := Str' T.
Variable eqT : forall T : str, T -> T -> Prop.
Variable op : forall T : str', T -> T.
Axiom eqT_op_Proper :
forall T : str, ((eqT T:str_str' T -> T -> Prop) ==> eqT T) (op (str_str'
T):T -> T).
Goal forall T, exists R, Proper (eqT T ==> R) (op (str_str' T)).
intros. econstructor. (* apply (eqT_op_Proper _). fails, same with refine *)
apply (eqT_op_Proper T). (* success *)
The problem is that the unification (noted ~) fails on: (sort' (str_str' ?1))
~ (sort T).
Note that in the first term we don't know what the existential ?1 is.
If we reduced these to normal form we'd get [?1 ~ let (sort) := T in sort]
and it would succeed,
but we don't reduce terms that contain existentials like that. Instead,
whenever we encounter
a unification problem of the form [match c return p with .. end ~ match c'
return p' with .. end]
the only considered solution is [p ~ p'], [c ~ c'] and branches are pointwise
unifiable (i.e. case
expressions are considered rigid). This is a known flaw of the (two)
unification algorithm(s) inside
Coq.
-- Matthieu
- [Coq-Club] Interaction between Setoids and Canonical Structures, Cyril Cohen
- Re: [Coq-Club] Interaction between Setoids and Canonical Structures,
Cyril Cohen
Carsten Varming
Cyril Cohen
Carsten Varming
- Re: [Coq-Club] Interaction between Setoids and Canonical Structures, Cyril Cohen
- Re: [Coq-Club] Interaction between Setoids and Canonical Structures, Matthieu Sozeau
Carsten Varming
Cyril Cohen
Carsten Varming
Cyril Cohen
