coq-club - Re: [Coq-Club] Interaction between Setoids and Canonical Structures
chronological Thread
  • To: Cyril Cohen <cohen AT crans.org>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Interaction between Setoids and Canonical Structures
  • Date: Tue, 14 Dec 2010 10:29:45 -0500 (EST)
On Mon, 13 Dec 2010, Cyril Cohen wrote:
Hi,
On 13/12/2010 16:04, Carsten Varming wrote:
The main problem is with the type class resolution.
The type of eqT in
the morphism declaration is (sort T), but the resolution algorithm is
looking for (sort' (str_str' T)), and it doesn't know that (sort T)
and (sort' (str_str' T)) are equal.
Thank you for this answer.
I tried to adapt your fix to the complete case, and now it works in the trivial cases. However, I still have issues each time the type of the arguments does not fit exactly the one I declared for the morphism. Here is a new reduced example of my problem.
This is exactly the same problem as above. Adding this does the trick:
Add Parametric Morphism (T : str) : (op' _ : T -> T)
with signature ((@eqT _ : sort'' (str'_str'' (str_str' _)) -> _ -> _) ==>
(@eqT _))%signature as eqT_opX'.
Admitted.
In
Goal forall (T : str) (a b : T), eqT _ a b -> eqT _ (op' _ (op _ a)) (op' _
(op _ b)).
The type of the second eqT is inferred as (str'_str'' (str_str' T)), and this type is not in the database.
Since (sort' (str_str' T)) and sort T are convertible, why does the resolution fail ?
I don't know. You would think that evaluating types to a normal form would be the right thing to do, but that not the way it is currently done.
Carsten
