- To: Matthieu Sozeau <mattam AT mattam.org>
- Cc: Carsten Varming <varming AT cmu.edu>, Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Interaction between Setoids and Canonical Structures
- Date: Wed, 15 Dec 2010 15:19:28 +0100
Hi,
Le 14/12/2010 19:18, Matthieu Sozeau a écrit :
> The problem is that the unification (noted ~) fails on: (sort' (str_str'
> ?1)) ~ (sort T).
> Note that in the first term we don't know what the existential ?1 is.
Thank you Matthieu for this explanation. When I have the time, I might
try to fix my problem by triggering a weaker unification (sort' ?1) ~
(sort T) which would succeed thanks to cannonical structure recognition.
Cheers,
Cyril
- [Coq-Club] Interaction between Setoids and Canonical Structures, Cyril Cohen
- Re: [Coq-Club] Interaction between Setoids and Canonical Structures,
Cyril Cohen
Carsten Varming
Cyril Cohen
Carsten Varming
- Re: [Coq-Club] Interaction between Setoids and Canonical Structures, Cyril Cohen
Matthieu Sozeau
Carsten Varming
Cyril Cohen
Carsten Varming
Cyril Cohen
