- To: Cyril Cohen <cohen AT crans.org>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Interaction between Setoids and Canonical Structures
- Date: Mon, 13 Dec 2010 10:04:43 -0500 (EST)
Hi,
The main problem is with the type class resolution. The type of eqT in the morphism declaration is (sort T), but the resolution algorithm is looking for (sort' (str_str' T)), and it doesn't know that (sort T) and
(sort' (str_str' T)) are equal.
Below I have changed the definition of your morphism such that it works.
Carsten Varming
Require Import Relation_Definitions Setoid Morphisms.
Variable A : Type.
Structure str := Str { sort :> Type }.
Structure str' := Str' { sort' :> Type }.
Definition str_str' (T : str) := Str' T.
Variable eqT : forall T : str, T -> T -> Prop.
Variable op : forall T : str', T -> bool.
Add Parametric Relation (T : str) : T (eqT T)
reflexivity proved by _
symmetry proved by _
transitivity proved by _ as eqT_rel.
Proof. Admitted.
Set Printing All.
Add Parametric Morphism (T : str) : (op (str_str' T))
with signature ((@eqT _ : sort' (str_str' T) -> _ -> _) ==> @eq _)%signature
as eqT_op.
Admitted.
(* Here comes the problem *)
Goal forall (T : str) (a b : T), eqT _ a b ->
op (str_str' T) b = true -> op (str_str' T) a = true.
Proof.
intros T a b eab ob.
rewrite -> (eab). (* <= it doesn't work *)
Abort.
On Mon, 13 Dec 2010, Cyril Cohen wrote:
On 13/12/2010 15:16, Cyril Cohen wrote:
I managed to reduce my issue to the joint example.
I'm sorry, I just noticed that I didn't even need to put canonical structures. Here is the new example.
- [Coq-Club] Interaction between Setoids and Canonical Structures, Cyril Cohen
- Re: [Coq-Club] Interaction between Setoids and Canonical Structures,
Cyril Cohen
- Re: [Coq-Club] Interaction between Setoids and Canonical Structures, Carsten Varming
Cyril Cohen
