coq-club - Re: [Coq-Club] What about a Coq ExtLib ?
chronological Thread
  • From: Thomas Braibant <thomas.braibant AT gmail.com>
  • To: Aaron Bohannon <bohannon AT cis.upenn.edu>
  • Cc: Thomas Braibant <thomas.braibant AT inrialpes.fr>, coq-club AT inria.fr, Tom Prince <tom.prince AT ualberta.net>, St�phane Glondu <steph AT glondu.net>, Pierre Boutillier <pierre.boutillier AT ens-lyon.org>, Bas Spitters <spitters AT cs.ru.nl>
  • Subject: Re: [Coq-Club] What about a Coq ExtLib ?
  • Date: Mon, 14 Mar 2011 11:18:29 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :cc:content-type:content-transfer-encoding; b=RFeKOxVNvGPChHga1y0bH734NFb5w/PymO1R/LIXoXzD3FK2hhvbMkGnTPJ86TuPXi 19mf4O0saazyCTlXxx7+7yyn+w4Aefc4wTm7tCwuG5SD5F0w3n0P/o6aU9k4+emS0GdM kT+LCxXfOrc9v2i3PO0dNL6hEjzDYukxx/Cpw=
Aaron wrote:
> As a prerequisite for such improvement, it seems critical to develop
> an official, written, agreed-upon style guide that is as thorough and
> detailed as possible (*).  The library code should (obviously) follow
> the style guide and be a perfect model for how users should write
> their own code.
> (*) The style guide should cover the parts of the Coq code that can be
> seen when looking through a library's coqdocs, i.e., the Gallina and
> generic tactic definitions.  A style guide for proof scripts would be
> a whole other can of worms and seems much less urgent.
While I agree that such a style guide is crucial, I think that, at the
moment, no one can tell whether, e.g., a partial function should
return an option, or a default value. Moreover, writing the guide
lines on how to write perfect code can take an infinite amount of
time. Thus, I think there should be a compromise between the amount of
guidelines that are set up before starting the project, and the
necessity to start the projet to see what kind of guidelines are
required. Maybe I am wrong, but I do not think people are planning to
write guidelines at the moment. However, kickstarting a repo of open
contributions may spark the writing of such guidelines.
Frederic wrote:
> But I don't think we need to worry too much about backward compatibilities
> with old contributions or the current standard lib, because we can simply
> use new name spaces.
Indeed, a good way to ensure backward compatibility would be to tag
stable releases of the current ext-lib (or to resort to module to tame
the name-spaces).
Thomas
