- From: Frederic Blanqui <frederic.blanqui AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Re: [coqdev] What about a Coq ExtLib ?
- Date: Mon, 21 Mar 2011 09:39:33 +0800
Le 19/03/2011 23:57, Daniel Schepler a écrit :
On Thursday 17 March 2011 13:21:46 Hugo Herbelin wrote:note that, with iff, you can also use rewrite, which is quite nice.
Nevertheless, I started to make public on Cocorico a set of tentativeHow about a guideline that authors should use Type wherever possible instead
guidelines that "we" expect users to follow before submitting an
addition or a modification to a library. I put the text on the wiki
(page http://coq.inria.fr/cocorico/HowToContributeToTheStandardLibrary)
so that anyone can discuss the guidelines, add new questions about
unclear or missing recommendations, comment about whether such or such
guideline is reasonable or not, etc. I hope that at some time, we will
have converged to something comprehensive and useful for everyone.
of restricting themselves to Set? (With an obvious exception for declaring
the universe of an inductive type with no input types.)
Also, I've found that as a practical matter, it's more difficult to use "if
and
only if" results than the equivalent pair of split results, because "apply ->"
and "apply<-" aren't as good at unification as the stock "apply" (in
particular they don't accept "with" specifiers). Is this something that
should
be mentioned in the guidelines, to split up "if and only if" results?
- Re: [Coq-Club] What about a Coq ExtLib ?, (continued)
AUGER Cedric
- Re: [Coq-Club] What about a Coq ExtLib ?, Gregory Malecha
- Re: [Coq-Club] What about a Coq ExtLib ?, Frederic Blanqui
- Re: [Coq-Club] What about a Coq ExtLib ?, Thomas Braibant
Peter Aczel
- Re: [Coq-Club] What about a Coq ExtLib ?, AUGER Cedric
- [Coq-Club] Re: [coqdev] What about a Coq ExtLib ?,
Hugo Herbelin
- Re: [Coq-Club] Re: [coqdev] What about a Coq ExtLib ?,
Daniel Schepler
Tom Prince
- Re: [Coq-Club] Re: [coqdev] What about a Coq ExtLib ?, Thomas Braibant
- Re: [Coq-Club] Re: [coqdev] What about a Coq ExtLib ?, Frederic Blanqui
Tom Prince
Daniel Schepler
- Message not available
- [Coq-Club] Re: [coqdev] What about a Coq ExtLib ?, Thomas Braibant
- Re: [Coq-Club] What about a Coq ExtLib ?, Guillaume Melquiond
AUGER Cedric
