coq-club - Re: [Coq-Club] What about a Coq ExtLib ?
chronological Thread
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] What about a Coq ExtLib ?
  • Date: Fri, 18 Mar 2011 18:48:33 +0100
Le Fri, 18 Mar 2011 14:41:00 +0000,
Peter Aczel
<petera AT cs.man.ac.uk>
 a écrit :
> Dear coq-club and coqdev members,
> Is there a simple way to bypass the standard library??
I am not sure it is what you want, but:
$ coqc --help
Usage: coqc <options> <Coq options> file...
options are:
  -image f  specify an alternative executable for Coq
Coq options are:
  -inputstate f          read state from file f.coq
  -is f                  (idem)
  -nois                  start with an empty state
  -outputstate f         write state in file f.coq
  -compat X.Y            provides compatibility support for Coq version
  X.Y
same things for coqtop and coqide.
I already used the "-nois" option succesfully; never tried the other
options.
With -nois option, you will only have the "Type" "Prop" and "Set"
constants defined at startup (but the predicativity of these sorts is
not changed by this option)
in coqide/coqtop there is a "-impredicative-set" option, but I find
strange I didn't saw it in the options of coqc, so it may not work.
> Any suggestions for how to proceed would be welcome.  I want to have a
> module type/record type/type class for the notion of a logic, relative
> to a sort of the types for
> the free and bound variables of the logic.  This would have Parameter
> declarations for the logical
> operations and rules of inference and proofs of logic theorems and
> then implement different logics
> as instances of the logic module type/record type/type class.
> Best wishes,
> Peter Aczel
