coq-club - Re: [Coq-Club] Re: [coqdev] What about a Coq ExtLib ?
chronological Thread
  • To: Daniel Schepler <dschepler AT gmail.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Re: [coqdev] What about a Coq ExtLib ?
  • Date: Sat, 19 Mar 2011 09:26:53 -0700
> How about a guideline that authors should use Type wherever possible
> instead of restricting themselves to Set?  (With an obvious exception for
> declaring the universe of an inductive type with no input types.)
This certainly makes sense.
> Also, I've found that as a practical matter, it's more difficult to use "if
> and
> only if" results than the equivalent pair of split results, because "apply
> and "apply <-" aren't as good at unification as the stock "apply" (in
> particular they don't accept "with" specifiers).  Is this something that
> should
> be mentioned in the guidelines, to split up "if and only if" results?
I wonder if this is best fixed by improving apply -> and apply <-
rather than working around them in the library.
  Tom
