- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Rewrite involving typeclasses failing
- Date: Thu, 5 May 2011 19:00:10 -0700
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type; b=ceUnqykRqC5RgtZzsCpwHTFzFTCFfYPYb42wOEnxMNDLR50GWqivH3BFrVuk+7DNig fQek5KqTVXz1wI10FuhBeeQTyzQVYKu0c2TvVQ5gNLOj/JDausdBis/NHcMRDQLyefQ1 4fGAH6L5Oaotwz2QtPJrkBmvFSc31aRBn94vg=
I've been trying to extract and add to selected portions of MathClasses for some proof formalization I'm doing. I ran into a problem in this:
Program Instance Ring_Semiring `{Ring R} : Semiring R.
Solve Obligations using repeat (typeclasses eauto || constructor).
Next Obligation.
intro x.
apply (left_cancel (x:=mult0 zero x) (op:=plus0)).
rewrite <- distr_l.
repeat rewrite (_:RightIdentity plus0 zero).
reflexivity.
Qed.
Next Obligation.
intro x.
apply (left_cancel (x:=mult0 x zero) (op:=plus0)).
rewrite <- distr_r.
reflexivity.
Qed.
Here I really wanted to use "repeat rewrite right_identity" instead of "repeat rewrite (_:RightIdentity plus0 zero)". But for some reason that doesn't work: it does nothing, and the plain rewrite just displays "Found no subterm matching "?54072 ?65488 ?54073" in the current goal". It even turns out that with "Check right_identity." the first instance it finds is exactly the one I want. And if I "pose proof right_identity as H1; repeat rewrite H1" that works.
Does anybody have any ideas off the top of their heads why this might be happening? I can send the whole file via private email if you want, but it's a bit large to post on the list.
Daniel Schepler
- [Coq-Club] Rewrite involving typeclasses failing, Daniel Schepler
- Re: [Coq-Club] Rewrite involving typeclasses failing,
Robbert Krebbers
- [Coq-Club] Breaking typeclass instance cycles,
Daniel Schepler
- Re: [Coq-Club] Breaking typeclass instance cycles,
Tom Prince
- Re: [Coq-Club] Breaking typeclass instance cycles, Matthieu Sozeau
- Message not available
- Re: [Coq-Club] Breaking typeclass instance cycles, Paolo Herms
Tom Prince
Daniel Schepler
Robbert Krebbers
