coq-club - [Coq-Club] Breaking typeclass instance cycles
chronological Thread
  • To: Robbert Krebbers <mail AT robbertkrebbers.nl>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: [Coq-Club] Breaking typeclass instance cycles
  • Date: Fri, 6 May 2011 09:58:49 -0700
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=from:to:subject:date:user-agent:cc:references:in-reply-to :mime-version:content-type:content-transfer-encoding:message-id; b=uHMwtb9zhu+yc30IolXVvpsCHReRHbdViqVFrnsdc08sYrmiXFF0JT/mZBYj47Oh/h YRAMUHJf+SatrUfc2jRIRXuEwiWXTWypyRhEDqMzuiNHAOg/mjG5gZSUcaJ1Swz2bGP5 LsHvqbEjHSTIl8pLcT7jgDC/IhGHlTCkHtDXY=
On Friday 06 May 2011 00:54:46 Robbert Krebbers wrote:
> Hi,
> I think it is because you don't refer to the "canonical names" of the
> operations. So, instead of: apply (left_cancel (x:=mult0 zero x)
> (op:=plus0)).
> you should write:
>   apply (left_cancel (x:=0 * x) (op:=(+))).
Thanks, indeed first doing a "change (0*x==0)" and then using canonical names
did seem to work.
Now, my next question: I have a class and instances:
Class CommutesWith `{Eqv X} (op:X->X->X) (x y:X) : Prop :=
| commutes_with: op x y == op y x.
Program Instance CommutesWithSelf `{Eqv X} `{!Reflexive eqv} x :
  CommutesWith op x x.
Program Lemma CommutesWithRev `{Eqv X} `{!Symmetric eqv}
  `{!CommutesWith op x y} : CommutesWith op y x.
It seems that directly making the last one into an instance creates loops,
which is understandable.  My solution to this was:
Definition BlockCommutesWithRev {X} (op:X->X->X) (x y:X) : Prop := True.
Ltac try_CommutesWithRev :=
  match goal with
  | [ _:BlockCommutesWithRev ?op ?x ?y |- CommutesWith ?op ?x ?y ] => fail 1
  | [ |- CommutesWith ?op ?x ?y ] =>
       pose proof (I:BlockCommutesWithRev op y x);
           class_apply @CommutesWithRev
  end.
Hint Extern 10 (CommutesWith _ _ _) => try_CommutesWithRev :
  typeclass_instances.
I was wondering if there was some easier way to accomplish this.  Or at least
a way that would avoid creating the extraneous "let H2:=I in ..." that
results
in the generated proof terms.  (I see in the original MathClasses files I
downloaded, there was a commented question about similar things for
LeftIdentity -> Commutative -> RightIdentity and vice versa.)
Daniel Schepler
