- From: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
- To: Tom Prince <tom.prince AT ualberta.net>
- Cc: Daniel Schepler <dschepler AT gmail.com>, Robbert Krebbers <mail AT robbertkrebbers.nl>, Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Breaking typeclass instance cycles
- Date: Fri, 6 May 2011 22:18:08 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=subject:mime-version:content-type:from:in-reply-to:date:cc :content-transfer-encoding:message-id:references:to:x-mailer; b=NGfwBew/DdfNXE6yCQeKmmccMR6bawkOYCkIiNNvlilG4gtZV5ZSf7rrWfpFQcLwPb y8tOYA+jnqeNELyhXApS/b+KjjZ4jzhU9lNeq2QQXTN/Uqjct3IlNPgVKG47uMIEci7c QqnXNr8WH1HzjT5kO9s1oEYjGf1v3sH7kHYXg=
Hi,
I don't think there is a better solution yet either. However I'm working
on adding a feature that would allow the user to specify cuts in the proof
search using regular expressions on paths to forbid. I think it would solve
this particular problem.
Le 6 mai 2011 à 20:44, Tom Prince a écrit :
> On 2011-05-06, Daniel Schepler wrote:
>> On Friday 06 May 2011 00:54:46 Robbert Krebbers wrote:
>> Definition BlockCommutesWithRev {X} (op:X->X->X) (x y:X) : Prop := True.
>> Ltac try_CommutesWithRev :=
>> match goal with
>> | [ _:BlockCommutesWithRev ?op ?x ?y |- CommutesWith ?op ?x ?y ] => fail 1
>> | [ |- CommutesWith ?op ?x ?y ] =>
>> pose proof (I:BlockCommutesWithRev op y x);
>> class_apply @CommutesWithRev
>> end.
>> Hint Extern 10 (CommutesWith _ _ _) => try_CommutesWithRev :
>> typeclass_instances.
> I just implemented this the other day for categories.dual.flipA (from
> math-classes). I don't know of a better way, or how to implement it without
> the
> extraneous let. I think though, you probably want to make
> BlcokCommutesWithRev a CoInductive (I got the idea from
> Classes.Morphisms.normalization_done. The benifit of CoInductive is that
> it isn't convertible with anything, but does generate any induction
> principles.
> I don't think the extraneous let is a problem for CommutesWith, since
> the structure of proof terms doesn't matter.
> In my case however, the class lives in Type, so I care which case is
> picked. I want it deduced where other things force it, but if I do the
> following, then when I try to get it to deduce something that isn't
> constrained as dual.flipA, it still applies the tactic.
> Class Arrows (O: Type): Type := Arrow: O → O → Type.
> Instance flipA {Object} {A: Arrows Object}: Arrows Object := flip A.
> CoInductive dual_arrows_done (T: Type) : Prop := did_dual_arrows.
> Hint Extern 100 (Arrows ?x) => match goal with
> | _ : dual_arrows_done x |- _ => fail 1
> | |- _ => let H:=fresh "H" in set
> (H:=did_dual_arrows x); class_apply @flipA
> end : typeclass_instances.
There is no way to tell if a flipA should be triggerd here, is there?
If you had a dummy [flipObject] definition to act as an index you could
control its application using an [Arrows (flipObject ?x)] pattern, but
I guess you don't want that.
-- Matthieu
- [Coq-Club] Rewrite involving typeclasses failing, Daniel Schepler
- Re: [Coq-Club] Rewrite involving typeclasses failing,
Robbert Krebbers
- [Coq-Club] Breaking typeclass instance cycles,
Daniel Schepler
- Re: [Coq-Club] Breaking typeclass instance cycles,
Tom Prince
- Re: [Coq-Club] Breaking typeclass instance cycles, Matthieu Sozeau
- Message not available
- Re: [Coq-Club] Breaking typeclass instance cycles, Paolo Herms
Tom Prince
Daniel Schepler
Robbert Krebbers
