coq-club - Re: [Coq-Club] Rewrite involving typeclasses failing
chronological Thread
  • From: Robbert Krebbers <mail AT robbertkrebbers.nl>
  • To: Daniel Schepler <dschepler AT gmail.com>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Rewrite involving typeclasses failing
  • Date: Fri, 06 May 2011 09:54:46 +0200
Hi,
I think it is because you don't refer to the "canonical names" of the
operations. So, instead of:
 apply (left_cancel (x:=mult0 zero x) (op:=plus0)).
you should write:
 apply (left_cancel (x:=0 * x) (op:=(+))).
The problem is that you probably have an instance (theory.rings.plus_0_l in
mathclasses) like:
  RightIdentity (@ring_plus R plus0) (@ring_zero R zero)
However, if your goal contains (plus0 zero zero), the system won't be able to
figure out that it matches.
Moreover, there is another reason to refer to the canonical names: the names (plus0, mult0, zero) are automatically generated and hence very fragile. So I would prove the LeftAbsorb property as follows:
Require Import abstract_algebra theory.rings.
Instance ring_mult_0_r `{Ring R} : LeftAbsorb (.*.) 0.
Proof.
  intros x.
  apply (left_cancellation (+) (0 * x)).
  rewrite <-distribute_r.
  rewrite !right_identity.
  reflexivity.
Qed.
Best,
Robbert
On 05/06/2011 04:00 AM, Daniel Schepler wrote:
I've been trying to extract and add to selected portions of MathClasses for some proof formalization I'm doing. I ran into a problem in this:
Program Instance Ring_Semiring `{Ring R} : Semiring R.
Solve Obligations using repeat (typeclasses eauto || constructor).
Next Obligation.
intro x.
rewrite <- distr_l.
repeat rewrite (_:RightIdentity plus0 zero).
reflexivity.
Qed.
Next Obligation.
intro x.
apply (left_cancel (x:=mult0 x zero) (op:=plus0)).
rewrite <- distr_r.
reflexivity.
Qed.
Here I really wanted to use "repeat rewrite right_identity" instead of "repeat rewrite (_:RightIdentity plus0 zero)". But for some reason that doesn't work: it does nothing, and the plain rewrite just displays "Found no subterm matching "?54072 ?65488 ?54073" in the current goal". It even turns out that with "Check right_identity." the first instance it finds is exactly the one I want. And if I "pose proof right_identity as H1; repeat rewrite H1" that works.
Does anybody have any ideas off the top of their heads why this might be happening? I can send the whole file via private email if you want, but it's a bit large to post on the list.
Daniel Schepler
