- To: Jeffrey Terrell <jeffrey.terrell AT kcl.ac.uk>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Type of matched item
- Date: Wed, 17 Aug 2011 19:01:26 +0200
Le 17/08/2011 18:26, Jeffrey Terrell a écrit :
In f, are X and X0 the same set?
Inductive T : Set -> Type :=
Build_T : forall X : Set, T X.
Definition f (X : Set) (t : T X) (x : X) :=
match t with Build_T X0 => forall x0 : X0, x = x0 end.
It depends on what you mean by "the same". They are not convertible, but you can prove that they are equal. If you need to keep some relation between dependencies of the type of the matched item, and the arguments of constructors in branches, you have to use "as ... in ... return ..." annotations (see the "Extended pattern-matching" chapter of the manual).
In you case, by carefully taking care of dependencies, you can directly write:
Definition f (X : Set) (t : T X) :=
match t in T X return X -> _ with
Build_T X0 => fun x => forall x0 : X0, x = x0
end.
Cheers,
Stéphane
- [Coq-Club] Type of matched item, Jeffrey Terrell
- Re: [Coq-Club] Type of matched item, Dimitri Hendriks
- Re: [Coq-Club] Type of matched item, David Baelde
- <Possible follow-ups>
Jeffrey Terrell
- Re: [Coq-Club] Type of matched item, Stéphane Glondu
Jeffrey Terrell
- Re: [Coq-Club] Type of matched item, Adam Chlipala
- Re: [Coq-Club] Type of matched item, AUGER Cedric
Jeffrey Terrell
