- To: Jeffrey Terrell <jeffrey.terrell AT kcl.ac.uk>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Type of matched item
- Date: Sun, 21 Aug 2011 14:56:58 -0400
Jeffrey Terrell wrote:
Thanks for your help. There's a very good primer on pattern matching in sections 2 and 3 of "A New Elimination Rule for the Calculus of Inductive Constructions" by Barras et al. It references what appears to be a primary source on pattern matching, namely Coquand's 1992 paper on "Pattern Matching with Dependent Types". Does anyone know where I can obtain a copy of this paper?
I treat the subject in a more tutorial style in CPDT:
http://adam.chlipala.net/cpdt/
You should find all the important design patterns there, including the one that was suggested in response to your question here.
- [Coq-Club] Type of matched item, Jeffrey Terrell
- Re: [Coq-Club] Type of matched item, Dimitri Hendriks
- Re: [Coq-Club] Type of matched item, David Baelde
- <Possible follow-ups>
Jeffrey Terrell
Stéphane Glondu
Jeffrey Terrell
- Re: [Coq-Club] Type of matched item, Adam Chlipala
- Re: [Coq-Club] Type of matched item, AUGER Cedric
Jeffrey Terrell
Stéphane Glondu
