- To: Jeffrey Terrell <jeff AT abstractsolutions.co.uk>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Type of matched item
- Date: Thu, 18 Aug 2011 16:57:24 +0200
Hi Jeffrey,
Sometimes it's obvious that two things are equal, you just have to
compute and look, for example in x = x or 1+1 = 2. Sometimes it takes
a (more or less) complex argument. For example, 1+x = x+1 holds but it
takes more than computing a sum to check it -- you have to prove it by
induction on the natural number x. The boundary between trivial and
non-trivial varies from one human to another, and from one system to
another.
In your code Coq, it is not obvious that x and x0 have the same type.
This is because of a limitation in the typing of pattern matching. It
requires you to write a proof by hand or, as Dimitri pointed out,
rewrite the definition in a way that makes things obvious for Coq.
Hope this helps,
David
- [Coq-Club] Type of matched item, Jeffrey Terrell
- Re: [Coq-Club] Type of matched item, Dimitri Hendriks
- Re: [Coq-Club] Type of matched item, David Baelde
- <Possible follow-ups>
Jeffrey Terrell
Stéphane Glondu
Jeffrey Terrell
- Re: [Coq-Club] Type of matched item, Adam Chlipala
- Re: [Coq-Club] Type of matched item, AUGER Cedric
Jeffrey Terrell
Stéphane Glondu
