coq-club - Re: [Coq-Club] Type of matched item
chronological Thread
  • To: Jeffrey Terrell <jeff AT abstractsolutions.co.uk>
  • Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Type of matched item
  • Date: Thu, 18 Aug 2011 16:47:40 +0200
It helps to introduce x after the pattern matching on t,
since its type X depends on the outcome, so:
Definition f (X : Set) (t : T X) : X -> Prop :=
  match t (* in T X return X -> Prop *) with
    Build_T X0 => fun x => forall x0 : X0, x = x0
  end.
Dimitri
On Aug 17, 2011, at 18:11 , Jeffrey Terrell wrote:
> In f, are X and X0 the same set?
> Inductive T : Set -> Type :=
>   Build_T : forall X : Set, T X.
> Definition f (X : Set) (t : T X) (x : X) :=
>   match t with Build_T X0 => forall x0 : X0, x = x0 end.
> If they are, why does Coq reject the expression x = x0?
> If they're not, how are they related?
> Thanks. Jeff.
