- From: "Carlos.SIMPSON" <Carlos.Simpson AT unice.fr>
- To: Victor Porton <porton AT narod.ru>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Re: Where is the set theory?
- Date: Thu, 03 Nov 2011 11:24:36 +0100
Dear Victor,
Some other references which are relevant and more up-to-date are the works
by Jose' Grimm:
http://hal.archives-ouvertes.fr/inria-00408143/
http://hal.archives-ouvertes.fr/inria-00440786/
with the code at http://www-sop.inria.fr/apics/gaia/
It should be pointed out that the idea of saying that my axioms represent some kind of `ZFC',
was maybe too hasty. The axiom schemes of ZFC have been replaced by statements of the
form (forall P, ...), i.e. statements quantified over propositions (or arrows Ens->Prop or whatever).
The exact logical status of those, in comparison with an axiom scheme in the classical sense
of an infinite list of explicit axioms, doesn't seem (to me) easy to understand.
In order to be able to study this kind of question further, it would be really great if some
kind of system could be introduced to do large-scale reflection; for example in this particular
case we would like to be able to use the notational and unification facilities of coq, on the
restricted language of statements in set-theory; but then to be able to reflect those into
actual statements in the ground level of coq. That might also go towards answering
your previous question Victor:
On 11/02/2011 01:49 PM, Victor Porton wrote:
Probably a stupid question:The point of this request being, that you can pretty easily define a language CIC or at least CC inside
Why Coq has special language for writing new tactics, while Coq proofs can be
turn into programs? Can't programs generated from existence proof be use
instead of tactic scripts?
Coq (see the Coq-in-Coq contribution for example); however, as far as I know, you can't then
use the overall big Coq program in order to handle the de Bruijn indices of your sub-language,
also to do the shift operation and generally unify and other things like that.
A large-scale reflection system would also be fantastically useful for interpreting
Voevodsky's homotopy type theory, back into a more standard setting.
---Carlos
On 11/03/2011 12:59 AM, Victor Porton wrote:
Oh, I found it:
http://arxiv.ccsd.cnrs.fr/e-print/math/0402336v1
It is from this article:
http://arxiv.ccsd.cnrs.fr/abs/math/0402336v1
Now, admins, put these links to your wiki. I have no permission to edit the
page I intended to.
03.11.2011, 03:38, "Victor
Porton"<porton AT narod.ru>:
The article at http://arxiv.org/abs/math/0311260v2 about a formalization of ZF in Coq
contains "and also contains as a tar-attachment to the source file the revised and
expanded version of the proof development which had been attached to
math.HO/0311260".
I have seen this .tar file earlier but now cannot find it again. Where is the
tar with Coq sources?
We need to put a reference to that tar somewhere to Cocorico in order to make
its finding easier. It is an important, and as it seems to me, a well written
system of modules. It should be easily findable for visitors of Coq site (now
it isn't).
Carlos T. Simpson
C.N.R.S., Laboratoire J. A. Dieudonne, Universite de Nice-Sophia Antipolis
"Homotopy Theory of Higher Categories" now published!
Cambridge University Press, October 2011
http://www.cambridge.org/gb/knowledge/isbn/item6172978/
- [Coq-Club] Where is the set theory?, Victor Porton
- Re: [Coq-Club] Where is the set theory?, Adam Chlipala
- [Coq-Club] Re: Where is the set theory?,
Victor Porton
- Re: [Coq-Club] Re: Where is the set theory?, Carlos.SIMPSON
- <Possible follow-ups>
Victor Porton
Daniel Schepler
Victor Porton
Andrej Bauer
- Re: [Coq-Club] Where is the set theory?, Daniel Schepler
- Message not available
- Re: [Coq-Club] Where is the set theory?, Victor Porton
- Re: [Coq-Club] Where is the set theory?, Andrej Bauer
Andrej Bauer
Victor Porton
Daniel Schepler
