- To: Andrej Bauer <andrej.bauer AT andrej.com>, Coq <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Where is the set theory?
- Date: Fri, 04 Nov 2011 01:25:57 +0400
- Envelope-from: porton AT yandex.ru
04.11.2011, 01:22, "Andrej Bauer"
<andrej.bauer AT andrej.com>:
>> šBut what if I want to write "supremum S == supremum T"? (to add more
>> complexity, the first and the second supremum may be taken on different
>> sets.)
> You coudl write for example as
> šššexists x, supremum S x /\ supremum T x
It is bad to introduce an extra variable.
> But if you have a lot of suprema and you work with complete posets,
> then it might be better to formalize complete posets with an actual
> operation "sup", so you could just write "sup S = sup T".
The trouble is that I work with arbitrary (non-complete) posets.
If I worked with complete posets only, there would be no problem.
Victor Porton - http://portonvictor.org
- Re: [Coq-Club] Re: Where is the set theory?, (continued)
- Re: [Coq-Club] Re: Where is the set theory?, Carlos.SIMPSON
- Re: [Coq-Club] Where is the set theory?,
Victor Porton
Daniel Schepler
Victor Porton
Andrej Bauer
- Re: [Coq-Club] Where is the set theory?, Daniel Schepler
- Message not available
- Re: [Coq-Club] Where is the set theory?, Victor Porton
- Re: [Coq-Club] Where is the set theory?, Andrej Bauer
- Re: [Coq-Club] Where is the set theory?, roconnor
Andrej Bauer
- Re: [Coq-Club] Where is the set theory?, Adam Chlipala
Victor Porton
Daniel Schepler
