coq-club - Re: [Coq-Club] Where is the set theory?
chronological Thread
  • To: Andrej Bauer <andrej.bauer AT andrej.com>, Coq <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Where is the set theory?
  • Date: Fri, 04 Nov 2011 02:07:26 +0400
  • Envelope-from: porton AT yandex.ru
04.11.2011, 01:56, "Andrej Bauer"
<andrej.bauer AT andrej.com>:
>>>> ššBut what if I want to write "supremum S == supremum T"? (to add more
>>>> complexity, the first and the second supremum may be taken on different
>>>> sets.)
>>> šYou could write for example as
>>> ššššexists x, supremum S x /\ supremum T x
>> šIt is bad to introduce an extra variable.
> You can still write "supremum S == supremum T" if you mutliate Coq's
> notation mechanisms enough. But as I said, don't go crazy with
> misleading notation.
> By the way, if supremum of S is computed in the poset P and supremum
> of T is computed in the poset Q, then in type theory it does not make
> sense to compare the suprema. More generally, if x has type X and y
> has type Y, then it makes no sense to state or ask "x = y". It's
> simply not something you can write down. You may think this is an
> obstacle, but it isn't.
> If you know how to express the fact that S and T have the same
> supremum without using any quantifiers, please let me know.
set_of_suprema S == set_of_suprema T
Or we can use Option from Coq core modules to represent a supremum or None to
mean no suprema.
Victor Porton - http://portonvictor.org
