coq-club - Re: [Coq-Club] Does Coq actively convert things to Prop?
chronological Thread
  • To: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Does Coq actively convert things to Prop?
  • Date: Wed, 18 Apr 2012 11:48:47 +0200
Thank you for quick answers.
Frederic writes:
>> Inductive Q (x : A) : A ->  Type := horn : Q x x.
> The "problem" seems to be here already since, for Coq, Q has type
> A->A->Prop instead of A->A->Type as written
> explicitly.
But I explicitly require that Q map to Type... I see now that Coq is
lying to me, because "Print Q" leads me to believe that Q maps into
Type (it says "Inductive Q (x : A) : A -> Type :=  horn : Q x x"),
whereas
Parameter a : A.
Check (Q a).
tells me that Q a is in Prop. Can I force Q to map into Type somehow,
perhaps by using another layer of indirection?
> As far as homotopy type theory goes, as long as you don't mention Prop
> explicitely (which coerces inductive into > doing some kind of squashing,
> hence going beyond the power of MLTT+univalence), you can ignore Prop
> safely.
I find this hat do believe, not to mention it is very non-Coq-like. My
options seem to be:
(a) use the old definition of paths, which does not support rewriting.
(b) "trust" Coq and Prop.
(c) buy someone a beer to change Coq so it does not do this (the best
would be to make it configurable, I suppose).
I am in favor of (c) because the HoTT people might be the only ones
who really care about the issue. Vladimir Voevodsky's Foundations
patches don't seem to address this issue, or am I wrong?
With kind regards,
Andrej
