- To: Andrej Bauer <andrej.bauer AT andrej.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Does Coq actively convert things to Prop?
- Date: Wed, 18 Apr 2012 12:48:18 +0100
On Wed, Apr 18, 2012 at 01:36:57PM +0200, Andrej Bauer wrote:
> I am not proposing an incompatibility change, I think. I am proposing
> that the type should be honored when explicitly given. Because I
> explicitly defined that Q should map to Type, it should map to Type.
> If I asked Coq to _infer_ the type and it decided it was Prop, then I
> would have no objection. But as far as I am concerned this is a bug.
> If I define
> Definition cow : Bovine := ....
> then cow should be Bovine and not something else. I am tempted to file
> a bug report.
I've only used Coq for about a month so perhaps I don't appreciate the issues
involved.
However it does seem reasonable to me that you should get what you ask for!
Regards,
Bernard
- [Coq-Club] Does Coq actively convert things to Prop?, Andrej Bauer
- Re: [Coq-Club] Does Coq actively convert things to Prop?,
Frederic Blanqui
Arnaud Spiwack
Andrej Bauer
- Re: [Coq-Club] Does Coq actively convert things to Prop?, Andrej Bauer
Arnaud Spiwack
Andrej Bauer
- Re: [Coq-Club] Does Coq actively convert things to Prop?, Bernard Hurley
- Re: [Coq-Club] Does Coq actively convert things to Prop?, AUGER Cédric
- Re: [Coq-Club] Does Coq actively convert things to Prop?, Frederic Blanqui
- Re: [Coq-Club] Does Coq actively convert things to Prop?, Pierre Courtieu
- Re: [Coq-Club] Does Coq actively convert things to Prop?, Randy Pollack
Andrej Bauer
Andrej Bauer
Stéphane Glondu
- Re: [Coq-Club] Does Coq actively convert things to Prop?, Frédéric Tuong
Arnaud Spiwack
Frederic Blanqui
- Re: [Coq-Club] Does Coq actively convert things to Prop?, Guillaume Brunerie
