- From: Frederic Blanqui <frederic.blanqui AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Does Coq actively convert things to Prop?
- Date: Thu, 19 Apr 2012 11:19:29 +0800
Hello.
I agree with Andrej that this is not a desirable property to do type inference when a type is explicitly given. Is this documented somewhere? Anyway, the minimum would be to output some warning saying that the inductive type in fact lives in a different universe than the one given by the user.
In a variant of Andrej's example, giving no type has indeed the same effect:
Parameter A : Type.
Inductive Q' (x : A) := horn : Q' x.
Check Q'.
Q'
: A -> Prop
Inductive Q (x : A) : Type := h : Q x.
Check Q.
Q
: A -> Prop
Frederic.
Le 19/04/2012 05:03, AUGER Cédric a écrit :
Le Wed, 18 Apr 2012 13:51:07 +0200,
Andrej
Bauer<andrej.bauer AT andrej.com>
a écrit :
Here is another way to circumvent the problem, I think. First weParameter A : Type.
define the offending type which lands in Prop, then we define an alias
for it:
Parameter A : Type.
Definition cow (P : forall (x : A), A -> Type) : Type := forall x y :
A, P x y. Inductive Q' (x : A) : A -> Type := horn : Q' x x.
Definition Q : A -> A -> Type := Q'.
Definition q := cow Q.
Definition r := forall x y : A, Q x y.
Now r is in Type. But this still deserves to be a bug.
With kind regards,
Andrej
A, P x y. Inductive Q (x : A) : A -> Type := horn : Q x x.
Definition r : Type := forall x y : A, Q x y.
isn't type casting simpler than defining Q' ?
I always found that giving explicitely the type of a symbol at top
level was nicer that making the reader to mentaly perform the type
inference.
There r is really in Type and no more in Prop.
- [Coq-Club] Does Coq actively convert things to Prop?, Andrej Bauer
- Re: [Coq-Club] Does Coq actively convert things to Prop?,
Frederic Blanqui
Arnaud Spiwack
Andrej Bauer
- Re: [Coq-Club] Does Coq actively convert things to Prop?, Andrej Bauer
Arnaud Spiwack
Andrej Bauer
Bernard Hurley
- Re: [Coq-Club] Does Coq actively convert things to Prop?, AUGER Cédric
- Re: [Coq-Club] Does Coq actively convert things to Prop?, Frederic Blanqui
- Re: [Coq-Club] Does Coq actively convert things to Prop?, Pierre Courtieu
- Re: [Coq-Club] Does Coq actively convert things to Prop?, Bernard Hurley
- Re: [Coq-Club] Does Coq actively convert things to Prop?, Randy Pollack
Bernard Hurley
Andrej Bauer
Andrej Bauer
Stéphane Glondu
- Re: [Coq-Club] Does Coq actively convert things to Prop?, Frédéric Tuong
Arnaud Spiwack
Frederic Blanqui
Guillaume Brunerie
- Re: [Coq-Club] Does Coq actively convert things to Prop?, Michael Shulman
