coq-club - Re: [Coq-Club] Does Coq actively convert things to Prop?
chronological Thread
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Does Coq actively convert things to Prop?
  • Date: Wed, 18 Apr 2012 13:36:57 +0200
>> I find this hat do believe, not to mention it is very non-Coq-like.
> I don't understand why. This is what singleton elimitation does.
What I find hard to believe is that I can ignore Prop safely when I
work on HoTT and Coq secretly introduces Prop. How do I know it's not
going to do some proof-irrelevanty thingy?
>> (c) buy someone a beer to change Coq so it does not do this (the best
>> would be to make it configurable, I suppose).
> Well, that may require a mightier bribe than that, and a more secure
> position for yours truly. But it's not impossible either. Bear in mind that
> it would require a serious incompatibility with existing libraries as
> propositional equality would not support rewriting (at least not always).
I am not proposing an incompatibility change, I think. I am proposing
that the type should be honored when explicitly given. Because I
explicitly defined that Q should map to Type, it should map to Type.
If I asked Coq to _infer_ the type and it decided it was Prop, then I
would have no objection. But as far as I am concerned this is a bug.
If I define
Definition cow : Bovine := ....
then cow should be Bovine and not something else. I am tempted to file
a bug report.
With kind regards,
Andrej
